Height of 2500 Laramie
wvc90
Oct 29, 2020
Guys, I'm trying to decide if I can fit a 2500 Laramie into my garage. The max height is 81.5" for the garage and the dealer is telling me the truck is 82.5" to the top of the cab lights. I don't live anywhere close to the dealer. I thought the height was supposed to be closer to 80.5".
Do you have any advice or knowledge on the same?
Thanks much!
Zrojas
Apr 26, 2019
Prineville, Oregon
Thanks much!
80.1" according to Ram for a 2500 crew cab with an 8' bed.
Go to https://www.ramtrucks.com/ram-commercial/body-builders-guide.html and look at the dimensions for your configuration.
Brewbud
Brewmeister Meisterbrew
Aug 21, 2020
SoCal
I eyeballed my Laramie the other day with just a tape measure and it looked over 82" at that fin on top. I intend to pull out my level out to level across to the tape to get the real measurement but haven't done it yet.
LateToTheParty
Didn't want to come
Jul 29, 2020
Roxborough, CO
Just measured my 2020 Laramie 2500 w/ 8' bed. Air pressure in the stock Transforce set to 60 psi. It measures just shy of 80 inches to the top of the sharkfin. That 80.1 referenced above may have been true with the 95 psi that were in the tires when I took delivery a week ago.
LossPrev
Feb 19, 2020
My 2500 will not fit in my attached garage with the standard 7' door. I have to keep it in my pole shed that has an 8' door.
DontSlamMyRam
Dec 30, 2019
My '19 2500 won't clear a 7' door. Its been 8mo since I measured with a level at sharkfin and 82" is what I remember. That measurement was done on 35s but it was still a nogo on stockers. Mine resides in the shop which fortunately is an 8 footer. Happy shopping.
kristof
Aug 27, 2020
7ft door that's 84 in. If your door won't open all the way it will not clear adjust the garage door to stop when they are fully open like this
Not like this
Adjust it at the opener or the draw bar.
Per the link above my truck should be 80.2" tall . I never actually measure it but I did went thru a carwash which have 7ft 2in clearance :cool:
Not like this
My truck on 285/65R20 fits in my garage just fine (door like a shoulder thing that goes up).
Now if I could just figure out how to get another foot of length to actually use the garage to park it.
kristof
Aug 27, 2020
Dig two channels in the floor for tires ;)
Plum Cra Zy
Feb 21, 2020
Trying to figure out how that make the floor longer!!!!!!!!!!!;):eek: Maybe a comprehension problem on mine or his part?
TDRamOH
Jul 28, 2019
Not like this
This is exactly what I had to do. Fits no problem. There was an adjustment on the opener.
steve49
May 9, 2020
Show Low, AZ
My 19 2500 is stock, no bigger tires etc., and does fit with a 7ft garage door, although I wasn't sure when I first looked at the truck. Then I wasn't sure if the truck would clear with a fiberglass shell I wanted, but still had couple of inches clearance. My garage door has always been adjusted all the way up.
Riveyman
Jan 13, 2020
NC
Mine fits in the standard garage height wise, but it's too long to close the door. :(
