Having trouble filling tank
Ron045
Nov 6, 2021
Last half a dozen fills have been challenging. I have been to different pumps at different stations and the pump keeps clicking off every gallon or two.
Research leads me to believe that air is either trapped in the tank/line or Maybe a sensor is bad?
Are there any simple actions I can take before dragging it down to the dealer for a look? Truck is under warranty, but I'd hate to pay the deductible if I can perform the fix myself.
There is no deductible for warranty work….
The tank is not venting so the vent is likely plugged
Crusty old shellback
Apr 10, 2021
I just tilt the pump handle up until it gives a small gap at the bottom where the rubber nozzle cover contacts the tank filler neck for more air to escape. Works fine.
If they still had the old school nozzles without that rubber vent boot, there wouldnt be a problem.
My truck has been doing that since day one.
You should NOT have to do that
Apr 10, 2021
I agree.
It all depends on which pump I use and how many other are using pumps when I am.
It all has to do with delivery pressure.
That and Kommieforina and their CARB rules for gas vapors.
Nick
Mar 14, 2020
Shouldn't do that . I have used the large truck stop nozzles many times without problems and regular size nozzles I put on high every time , never a problem .
Apr 10, 2021
Where you fill up, does it have the big rubber boot to capture the fumes and put them back into the storage tanks?
A regular nozzle, I have no problems with. But the ones in Kommieforina I do.
dtsequeira
Dec 17, 2019
Mine does the same thing, I pull the vapor recover piece back and create a bigger gap . PITA for sure. I'm in California, I'm guessing the huge vapor recovery boot creates too much of a seal on the Ram gassers. This never happens on my 4Runner.
jetrinka
Jun 11, 2021
I have only had issues with one pump at a certain gas station. All others have been fine. I just avoid that station now.
BaseBD
Apr 25, 2022
Happens to me more often than not on 6.4 hemi as well. Pain in the butt to hold the nozzle for 45 gallons.
Nov 15, 2022
I thought it was the pump.
Just picked up a '22 2500 about 2 weeks ago.
Last week I was on half tank (50 gal tank), and the 1st few gallons had me using choice words in public, and kinda loud. LOL
I figure the vent is too small, doubt it is clogged.
TX, BTW, none of that stupid CARB crap here.
sanda
Dec 16, 2021
This is a common problem on Rams and requires a trip to the dealer.
Mike67
Nov 2, 2020
Like the others said, if you're using the "auto fill" on the pump, you have to keep the back of the pump handle up forcing the nozzle down. Unfortunately this is a "known" issue and that's what most of us do.
Ron045
Nov 6, 2021
It's ironic that you posted this today. I live in PA where we pump our own. I was in NJ yesterday where it is against the law to pump your own. I was concerned about the fill up and mentioned to the attendant he might have difficulty. The attendant must know about the problem too and said, "With these Rams, you need to put the nozzle in upside down".
Illegal to pump your own gas? What kind of stupidity is that?
