GVWR
2023ram3500owner
Apr 25, 2023
I have a 2023 ram 3500 4x4 crew cab 6.4L. GVWR is 11,400 lbs. what are the thoughts on exceeding this by 500 or 1000 lbs? Thanks
AH64ID
Moderator
Oct 5, 2021
Full send, just don’t exceed your axle ratings or tire ratings.
GVWR isn’t a legal rating for private use in many states. Axle and tire ratings are.
Billcf7
Sep 12, 2019
Can you prove that there are no sensors in the computers to detect payload and load put on transmission. GM and FORD have it, the only difference is they publish it.
jetrinka
Jun 11, 2021
The only thing I can think of that could provide any data like that may be the air suspension trucks which can detect squat (for lack of a better term) angle and inflate the bags accordingly.
AH64ID
Moderator
Oct 5, 2021
Even then there are plenty of variables for actual weight.
Transmission load isn’t an accurate indicator of weight either.
Billcf7
Sep 12, 2019
I have a HaulGauge that plugs into the OBD and it has been very accurate for payload and GVWR
The computers have no data logging otherwise the dealers would be able to check data logs to fix intermittent issues.
