Front drive shaft
BigBlack
Sep 23, 2019
Trying to follow the recommended maintenance on my truck I ran into a problem maybe someone can solve. It says lubricate front drive shaft for 4x4. Ive looked everywhere for the grease serts and could not find any anywhere. Are the 19s sealed? I’ve searched several online videos that have them but are older models. TIA
Gondul
Prince of Pintops
Mar 10, 2019
I haven't crawled under to look myself but a quick search indicates the HD 4x4 RAMs do not have a standard zerk fitting, it require a 'Lincoln Needle Fitting'
Bozo
Self-banned
Feb 24, 2020
That needle fitting presses into tiny cap/zerk area, hard to see initially, but it’s there. Manual calls for grease at every oil change. Theres even a sticker under hood.
Gondul
Prince of Pintops
Mar 10, 2019
Yeah... I'm pretty sure the dealer didn't do anything to mine on the oil change... guess I'm buying a needle fitting!
BigBlack
Sep 23, 2019
I’ve got a picture of what I got, seems that you may have to turn the shaft to get to it? On the picture, this is the only thing I have found so far.20995DD8-1C83-456F-9E77-9318B78EDEAF.jpeg
elephantrider
Hydraulic Lifter Crew
Sep 3, 2019
not a requirement on the '19 and up models, I didn't believe. they just didn't update the manuals.
elephantrider
Sep 3, 2019
I'm trying to find some of the links that talk about it while I'm working here so if anyone finds something post up.
iirc, the requirement was done away with, because of the updated front shaft.
DevilDodge
Nov 21, 2018
Age
46
Central Pennsylvania
Aketay
Apr 5, 2020
The new Rams have sealed u-joints. The front cardan , double u-joint, has been replaced with a constant velocity joint. The picture below is for the old style. The grease fitting was for the ball and socket, not the u-joints.
BigBlack
Sep 23, 2019
Thank you for clarifying
Aketay
Apr 5, 2020
Hard to find new picture so. I took one ol’ nasty.
BigBlack
Sep 23, 2019
Ok glad I know what I’m looking at now. I took several pics for this reason and it looks identical B7242B88-26B4-4ACA-91FE-480C2E4B3C2F.jpeg
jupp0r
Jul 15, 2020
Mine has some grease splattered in a pattern. Is this concerning?IMG_0189.jpg
BigBlack
Sep 23, 2019
I would keep an eye out for anything leaking prior and after driving, but chances are it may be a puddle of oil that you may have gone over.
jupp0r
Jul 15, 2020
It also has some lateral play at the CV joint, which I guess is not good. Probably need to replace the shaft (hopefully under warranty).
