Fog light for 2019 Tradesman
Olive2020
Mar 2, 2020
Hey guys, thanks for the info on the fog lamps. I am looking forward to adding these to my tradesman as well. One question.
@elephantrider
@Compshooter
What did you use for a connector/ harness to the bulb? Was it anything unique or special? Pictures from the backside would be awesome if possible.
Thanks,
2020 Olive green 2020 CCSB Tradesman
elephantrider
Hydraulic Lifter Crew
Sep 3, 2019
if you're talking about the crossover harness between the fogs, I just built a harness and used some h11 pigtails off of amazon.
Compshooter
Nov 7, 2019
@elephantrider
@Compshooter
I'm still waiting for my bezels to come in. But when they do I plan on using H11 connectors like these...
Tomstation4
Apr 16, 2020
Factory fog lights installed. Thanks to elephantrider for the part numbers. The dealer was no help at all. Wired them to up fitter switch #1 . Used a relay even though I really didn’t need to.
It looks great and I would like to do the same. Could you please send a list of part numbers including both lights, any bezels and brackets. Thanks!
2020Tradesman2500
Apr 30, 2020
I added factory fogs and wired them to a switch so I could have high beams and fogs simultaneously.
I had the dealer install the factory brake controller with no issues.
I just got my 2020 Tradesman, I put the OEM LED fog lights in the bumper, I have two OEM connectors for the LED lights and no idea how to wire. The fog lamps each have a four wire connector? would you by chance have a schematic on the wiring?
elephantrider
Sep 3, 2019
i don't have a schematic. i used the halogen lenses so it would match the headlights.
what color are the 4 wires ?
Cinderblock_sniper
Apr 4, 2020
I’m going to wire these into my upfit switch panel, which looks a bit intimidating, but first question, just connect the blacks together from R-L and ground to the frame, then connect the other word together and run them to the switch block?
If you have the Aux switches, there are two connectors under the hood near the firewall. You have a wire bundle that came with the option.
You just need to bring your 12V load into one of them and program the switch settings in the EVIC.
M Penwald
May 12, 2020
St. Louis, MO
I don't know if it helps or not, but I just looked at my '19 Tradesman with the factory LED fog lights (Safety Group). The driver's side LED fog has a white/yellow wire and a black wire. The passenger side LED has a white/orange wire and a black wire. Each light only has 2 wires connected. Based on the nature of the wiring now, I'm sure the LED's are wired separately from the factory such that the vehicle "sees" each LED fog light separately.
b307a1
Mar 2, 2020
Western NY.
Does anyone know the part number for the screws that are used to mount the actual fog light to the bracket. I ordered the lights, brackets and bezels.....the screws were not included.
Bozo
Self-banned
Feb 24, 2020
Those will be $3.99/ea. Thank you, FCA.:);) Typical these days where everything is a purchase item.
b307a1
Mar 2, 2020
Western NY.
Hahaha....I didn't find $3.99 that surprising. So I went looking around online and was pleasantly surprised to find them for $0.63.
dug
Oct 10, 2019
I just ordered all the parts (I think - bezel, bracket, hardware) to install fog lights on my Tradesman (when it arrives - just placed an order) minus the actual fog lamp. I intend to install the Baja Designs Fog Pocket kit (see link below) and need a little help with getting these wired up. I want to control the fog lights from one of the factory installed auxiliary switches I ordered with the truck. From reading on here and other forums, it sounds like I need some sort of harness to get from the fog lights to the auxiliary switch, right? I have no idea what materials I need to make this happen. Do I need a fuse? Relay? I'm pretty ignorant when it comes to the electrical side of things so forgive me if I'm way off.
Also, any opinion on SAE vs non-SAE lights?
Bozo
Self-banned
Feb 24, 2020
You do not have to go to the switch, there is a port on the firewall. You use the wire accessory kit that came with truck, if outfitted with aux switches.
If you have the Aux switch option, you should have a bag of wires and this instruction sheet.
P.S. The gray plug in that bag gets plugged in way up behind the dash about horizontal with the headlight switch and close to the firewall if you want to send power to the rear blunt cut wires by the spare tire. There are two loops in that bundle, ignition and bat+, that you can also tap into if needed. I'd fuse anything you add.
There's also a wire in that bundle that connects to the pass-thru labeled port on the AUX firewall connector. You can loop an aux position back through that pass-thru to bring a switched aux into the cab without drilling holes or pushing through another bundle. Light Grey firewall plug #4, circuit G425.
There will soon be a full document showing all those options with superb examples and wiring details put up by @thestuarts but I think he hasn't finished polishing it or published it yet. If he did, I missed it.
  • Ram_Heavy Duty Truck_ Pick Up_Aux Switch_2019+ revA.pdf
Squatch
Mar 21, 2020
Washington
Pretty sure each aux switch has its own fuse and relay, they are located in the little fuse box next to where you connect the wires on the drivers side firewall under the hood. It’s a apiece of cake.
dug
Oct 10, 2019
Thanks for the replies. I ordered my truck with the auxiliary switches (haven’t received truck yet) so I should expect to get a bag of wires. I assume I still need to purchase wires/harness to get from fog lights to firewall, right?
