steve49
With the 19 Laramie flares some have said they have to cut off a tab on the flare to get them fit the 2019, how many tabs are there to cut off? I want the OEM Laramie flares and keep the spats for added protection.
These flares look great. Can you share where you got these and also, is your truck leveled or stock?Here is mine:
You'll like them, other than the install on the front which I am still scratching my head on.Decided to order the Mopar off-road flares and confirmed that AEV uses them on the Prospector builds.
The front installs with the bolts for the inner fender well, and also 2 of these chincy little metal tabs that I had to beat the ever living crap out of the get into place and actually hold anything.I'm not sure I understand your reference to the installation on the front - more details please.
LOL I am mainly referring to the design. I'd rather drill 2 holes in my fenders and use bolts.Can a tab be Chincy and still need to have the crap beaten out of it? Lol
Are these Bushwacker Max Coverage? or regular size? Or the website paintedfenderflares.com?Here is mine:
The AEV ones require you to cut the fenders to a larger opening. You sure they are the same?Decided to order the Mopar off-road flares and confirmed that AEV uses them on the Prospector builds.
I believe @ramblinChet is correct.The AUV ones require you to cut the fenders to a larger opening. You sure they are the same?
the way i understand it is: The prospector comes with regular flares and 37”s. The prospector XL comes with cut out flares and 40”s. Two compared below.
Gotcha, forgot there were 2 versions. My bad; I go stick my nose in the corner now.
I just ordered and received the Power Wagon style flares (6MS35GXHAC....) and they don't have the indent at the top and look much like the Laramie style flares - don't look like they cover any more tire. Anyone else ordered the Power Wagon flares recently? If so, did you see the same thing or do your flares have the indents?The 19+ OEM flares are actually pretty inexpensive. And will fit 10+ HDs with very minor modifications to them.
The P/N's for the flat laramie style flares
6MS44TZZAC
6MS45TZZAC
6MS46TZZAC
6MS47TZZAC
The P/N's for the power wagon style flares with the upset at the top
6MS35GXHAC
6MS34GXHAC
6MS36GXHAB
6MS37GXHAB
The P/Ns for wheel spats that kind of interconnect to the above flares (black pieces that protect the bottom of the box & fenders)
These are the P/N's for a 6.5' box, an 8' box would need different pieces for the front/leading edge of the box
68362312AC
68362313AC
68362320AD
68362321AD
68362316AD
68362317AD
