Falken WildPeak AT3 285/65/20
mountainears
Mar 29, 2022
Just posting for others to reference what it looks like, I had trouble finding pics of these on stock truck, no leveling or lift. Tires are slightly taller, same width. Have used these tires on several trucks and have been happy.
Gear box
Dec 25, 2021
Thanks for posting these pictures. Are they pretty tolerable with tire howl? Windows up noticeable?
Xflight29
Feb 5, 2020
Have these on our 4Runner, like them enough to install on my Ram when it's time for new tires.
mountainears
Mar 29, 2022
If there is any road noise it is very minimal. Have had these tires on several trucks, love them.
AK_Rams
Aug 28, 2021
Anchorage, AK
I appreciate you both posting these pictures for us. I am looking at these same tires in the same size. Have you noticed a big difference in mpg with the bigger tire?
Razzman
Jan 10, 2021
I really didn't notice much of a difference. Just had to change the tire size in the BCM, you won't find that size listed; at least it wasn't there a year ago. I had to do it via tire circumference and even then I'm off a bit and need to redo it.
mountainears
Mar 29, 2022
That takes AlphaODB right? I haven’t done that yet, thinking it’s not too far off for now :)
Razzman
Jan 10, 2021
Yeah it does. Based on GPS -vs- Speedo I was 3 mph off after installing the tires.
mountainears
Mar 29, 2022
Thanks. I’ll get it done at some point. I have the cables but I have to pull the dash cluster out so I figured I would take notes of all the things I want to change and do them all at once.
If you got the right cable that plugs into the CAN bus blocks, you just pull the headlight switch panel to access (see linked thread).
If you have to pull the cluster, you bought a 1500 SGW cable or brick.
mountainears
Mar 29, 2022
I’ll read through. What I have is the ECRI plug that according to the video I saw you plug in for a little bit then remove.
I have a 2022 as well which I thought was different than the other years.
2022 HD is no different WRT SGW.
Yea, that's gonna require you pull the gauge cluster.
Ugh.
If you just bought it, send it back and get a proper bypass cable (Jimmy can also make you one) and AlfaOBD and a decent OBDII reader.
ECRI Vehicle Calibration Device with Security Bypass Module - Fits Jeep Wrangler JL & Gladiator JT - Requires in-APP Purchase PER Vehicle
Seems like a lot for a one trick pony.
