mountainears
- Joined
- Mar 29, 2022
Wonder when recall notices will go out for 22’s to get them installed….
Can and chassis truck or pickup?Got mine a few weeks ago.
He has a C&C.Can and chassis truck or pickup?
.He has a C&C.
Rotate your phone to landscape mode.For some reason I can’t see that on my end.
Do you use the tapatalk? I use a iPad with safari and always see sigs.Never knew that made a difference on here! Thanks!
I used Tapatalk when I first started but at some point last year around October it got really “glitchy” and didn’t want to work right with this forum. I started getting notifications way late, or sometimes not at all, and I had a period where I got inundated with repeat old email notifications from posts that had been made prior. Just got frustrated with it and I ended up just using safari web browser and then creating a favorite with my log in information saved. Loading pictures was also a hassle. It just seemed like overall it made this more complicated than it need be because it was like the “middleman”Do you use the tapatalk? I use a iPad with safari and always see sigs.
I’ve never been a fan of tapatalk.Do you use the tapatalk? I use a iPad with safari and always see sigs.
I read through the comments for this post and here’s what my 22 3500 does. At around 45 percent it’s going to regen and that can happen every 5 days or less if you drive it easy then it could be 3 days. Truck has 6,500 miles and has always done this. Guess maybe I should look and see if all the sensors are intact or not.
I’ll add that I use a keg of DEF every 6 weeks
I drive the truck 40 miles a day. If I run up the highway at 60mph + it’s 5 days. If I cut through the country on the back roads running 45 to 50mph it’s around 3 days. If I’m running with a loaded stock trailer or the camper around 70 mph the dpf gauge stays around 0 and cuts the regen to around 10 days.Need more info than just days or weeks.
Miles? Hours? Driving conditions?
I haven’t asked a dealer about it but did talk to the diesel mechanic that deletes most everyone’s trucks in the area and he’s says what mine is doing is common with other 22’s he’s dealt with.
Now my buddies 20 regens almost daily, he runs the dog outta it but he idles a lot so that’s probably why his is so frequent. I may idle mine 10 minutes on a cold morning but that’s about it.
The diesel mechanic told me not to let the truck set there and idle for prolonged periods because the trucks can’t take it.
Well if I drive 20 miles one way up the hwy that’s 19 minutes x 2, 38 minutes a day x 5 days isn’t but 3. something hours between regens. Sound excessive doesn’t it.. now if I go the back roads to the same location that adds 4 miles extra so that’s 24 miles but I’m running only around 50 mph and it will regen quicker and a good estimated guess on hours is 2 since it’s gonna happen in 3 days instead of 5 days. You can smell it before it regens every time. It’s like clockworkHow many engine hours between regens? Days doent mean anything.
The guy I talk to says that’s the same story he gets from others with 5th gens. I seen some of the reply’s say their dpf gauge gets 80% before it regens, mines never gotten over 45% and from what I researched that’s correct. I do think it’s excessive but compared to my buddies 20 it’s not. My nephews 17 use to do about the same but be corrected that problem so his gauge always reads 0 and his Def consumption is very minimal.That is excessive regens. You should be going 24 runtime hours based on what you are saying.
Smelling it before regen is also odd, there should be no change in smell prior to a regen, just during it.
