Nerd warning...
It is exactly "computer glitches" or rather bad programming. If pull up the Developer Tools built into your browser you will find that the in the backend RAM's
towing guide (click "Look up my vehicle") is returning an error. After you enter your VIN and click "Find" it wants to call:
https://www.ram.com/towingws/TowingServlet?vin=YOUR_VIN_HERE&serviceType=json&action=TOWINGINFOBYVIN , run that URL directly in your browser and you get:
Somewhere in the corporate offices of FCA/Chrysler or some contracted vendor, a software engineer isn't doing good job of QA'ing their code. He probably said something to the effect:
After a bit of playing around, I found that this URL may work in your browser to return you a raw data JSON object with your vehicle data. Swap in your VIN
My Result:
Might be a bit more readable in XML format depending on your browser:
Chrome here:
Very important note here for those not as well versed in this data, Base Curb Weight is not YOUR curb wieght, it is the estimated curb weight of a stripped, base model truck. Calculate your curb weight as
And as always, weigh your vehicle as you drive it (regularly loaded with all normal passengers) to get your most current numbers.
