DEF Excessive Usage
Gkockrow
Aug 24, 2021
I have a 2022 3500 with HO option and use about 1 gallon of DEF every 500 miles pulling my 10000 lbs 5 th wheel. My 2017 got about twice that with SO engine. Normal or excessive for HO? Thanks for input.
Thats normal for any 19+ truck they made the 4.5 gens pound the def back
jkempken
Nov 30, 2018
Normal, my 2020 SO used 7 gallons of DEF pulling about 8k lbs just under 3000 miles.
Sauksxs
Aug 2, 2021
We are on a trip from Arizona to Idaho 4500 miles so far did Durango to Ouray and the Tetons aong with the Big Horn mountains HO Drw pulling 18k TH around 300 MPG
MEGA HO
Jul 20, 2020
Alberta
As I understand it they made these 19+ trucks run hotter > cleaner > more NOx > higher DEF consumption. But it also technically means less DPF issues and I'll take less DPF issues over higher DEF consumption any day, only if DEF didn't have its set of serious issues.
jkempken
Nov 30, 2018
I'm ok with the size of the def tank, can get about 2000 miles towing before needing to refill, my buddy just got a minimax 1500 and that thing sucks def like crazy, had to put in 2 gallons after towing his boat 400 miles.
PRS
Feb 23, 2019
Arvada, Co.
Just did a 1500 mile trip in western Colorado and northeast Utah pulling an 18k 5th wheel. Mixture of high passes and normal Colorado terrain. Averaged 2.5% DEF to fuel use. We are post HPFP recall.
sstoner911
Sep 28, 2020
Part of this issue of DEF usage on the 2022 trucks, is that we are missing a DEF sensor that will be installed at a later once they have the parts.
waveslayer
Feb 26, 2022
How can you verify which models are missing this sensor...
My wife thinks I only have 3 guns
sstoner911
Sep 28, 2020
I believe it's all 2022s.
Gkockrow
Aug 24, 2021
Why didn’t Ram disclose this on a new purchase. Just going to recall? Pulling my fifth wheel I’m just eating DEF. 5 gallon tank hurts on cross country trips. Not easy to find at pump so always carrying spare fluid.
waveslayer
Feb 26, 2022
This was not disclosed to me either. I have put in 7 gallons of DEF with 3000 miles on my truck
Did you ask? Its nothing new and to my understanding you were required to sign a form saying you will bring it in when parts are available to replace the missing sensor
