Cooling Seat Not as good?
crzysnake137
Feb 1, 2019
Anyone have a problem with there cooling seats? Seems like mine barely work at all. My brother had a 4th gen with the cooled seats and they worked Way way better. Even on high I dont barely any cooling
Zrojas
Apr 26, 2019
Prineville, Oregon
Since they are just vented seats and pull from cabin air, I think that the lacking A/C may contribute to them not working very well. I can feel the air, but it's not always very cool.
1FastHemi
Jan 4, 2020
Mine seem to do a Good Job on High Setting and just Ok on Medium but on Low, I really don't notice much of anything ..
Which fan speed are you all having problems with ?
crzysnake137
Feb 1, 2019
All 3 speeds, I feel a tiny bit of air on high and that’s about it. My brother has a fourth gen and on high it feels like a leaf blower
volcomrr
Dec 31, 2019
I'd have to agree; same with mine. I have to run it on the high setting just to be able to feel it.
Gondul
Prince of Pintops
Mar 10, 2019
I never not run mine on high... breeze could be a smidge stronger but you can certainly feel the difference when the AC is actually cooling.
Rich
Banned Member
Feb 3, 2020
I only use mine on high and it works great, can actually feel cold air on my @$$ and blowing up the back ouf my shirt. Now I will admit, it does seam to give itself a break occasionally, I'm assuming to prevent overheating of the fan, kind of like heated sest on high
Dr__Bob
Jun 28, 2020
Riverside, CA
I've just tried mine on medium and haven't really noticed much. I'll give "high" a whirl and see.
UglyViking
Jul 11, 2020
I was stoked about this option but so far I've found it pretty lackluster. AC needs to be blowing hard for it to do anything it seems.
Omar RVA
Feb 26, 2020
OR
This. I found it works best when the AC is actually performing well (which is under like 85 degrees ambient temp). When working right it feels like you sat in a cold puddle which is a bit unsettling but at least it's cold like it's supposed to be when the leather's been baking in the sun. I bet if FCA ever resolves the AC issue (@RamCares - I hope y'all note it's not just the diesels with this problem) the vented seats will work way better.
OA
skaiskaiskai
Jun 3, 2020
Same here. I only run it on high setting, and after about 10 minutes of runtime I feel only minor changes in the temp in that area. I'm not sure if it's my body adjusting to the temp but it seems to almost go away after that initial 10 min run. It sure does make some noise too. I almost didn't buy my truck as both me and my wife were scrounging around trying to figure out what the static radio station noise was coming from. I had turned everything in the truck pretty much and finally realized it was the vented seats' air or fan noise.
Phil T
Jun 3, 2019
We really like our vented seats. They work really great. Maybe you have a restriction somewhere keeping the air flow from escaping.
