Coolant Question
Will_T
Jan 23, 2021
Southwest Oregon
My manual says to use "Mopar Antifreeze/Coolant 10 Year/150,000 mile". All the posts I read agree with this for the 6.7. However all those same posts describe that coolant as purple. Even the answered questions on the Amazon page selling the Mopar coolant say it is purple. The coolant in my truck is definitely not purple. It is bright pink as pink can be. Why would this be? Is the 10 year/150,000 mile coolant from the factory pink and the same bottled Mopar coolant purple? If I need to top off my coolant after doing the A/C fix valve install, I am uneasy about putting in purple coolant when the truck came with pink? Thanks for any advice/help.
Edit: I did find a couple of places, including Mopar.com, that say the correct coolant conforms to MS.90032. The coolant in the Amazon link is MS.12106. So that confuses things even further. Although several posts I read said that even though that Mopar coolant bottle does not say MS.90032, it is the correct one. But not having the number, and being purple instead of pink, makes me think it is not the correct one.
So simply put: Can anyone say for sure exactly what coolant I should use if I have to top mine off?
Aslong as its OAT your good to go, i run TRP HD coolant as i can get it cheap from my local supplier at the big rig shop
Will_T
Jan 23, 2021
Southwest Oregon
You definitely need to use OAT. Difference is, one is pre-diluted 50/50, and the other is concentrated.
Yes but none of the Mopar jugs say OAT on them anywhere unless I am blind to it for some reason. If you go to that Amazon link and look at the photo of the front and back of the jug, does it say OAK somewhere that I am missing?
Edit: I just looked more closely at the catalog Jimmy linked to and even though the photos are tough to see clearly, it looks like the 1 gallon jug of 50/50 on page 15 is the same as the Amazon jug: Part No. 68163849AB MS-12106
It may not say it or it may say organic acid technology. But thats irrelevant mopar has been using OAT since 2013 before that it was HOAT and if mixed can make a jelly like substance in the coolant… HOAT is typically green. OAT is usually orange, purple, red
Jimmy07
Re-coding from an easy-chair
Apr 5, 2020
Ok, disregard that I mentioned OAT, as that is just common knowledge for the 10yr/150,000 mile mopar coolant.
If you are using mopar coolant in your truck, you would use one of these two:
