I will definitely update here how it goes and what is required to change.If that one works, I'd be fine replacing mine every couple years for $10 each. I'll be interested in the process of getting it past the shift knob. Thanks for you're efforts!
Finally got the shift lever boot and installed. Can confirm, 68480815AA is what you need. Seems to be made of similar material as the original that came on my 2019. So my hopes are not high that it won’t erode away again over the next 2 years. It was only around $10 and 15 minutes of my time. Not sure it was worth going to the dealer for warranty replacement.Well I found a part number finally but it only shows up under 2020 steering column parts. Since it's only around $10 I'm going to take the plunge and see if it fits. If it does I guess I will order a bunch and treat them like a consumable
68480815AA: Mopar Gear Shift Lever Boot
Just take the bolt holding it in off. It‘s on the bottom at the base of the shaft. Small 10mm wrench or T30 torx bit. That was the hardest part of the whole thing, you have about 10 to 20 degrees of wrench movement to work with. But not hard at all. One of these is pretty handy and it’s what I use to tighten up the play that shifter gets about once a year (I should just put some loctite on it next time).Inquiring minds want to know....how did you remove the shift lever?
Check out Stitch boots on Instagram she does a lot of custom shift boots.
Watching. Someone’s going to get a lot of business soon!Thanks, gonna check this out.
She may have some universal products but she’s definitely capable and willing to make custom products.Has anyone purchased one these from StitchBoots.com yet?
I got the feeling that they're "one size fits all" which usually translates to "kinda fits". Also the black leather one looked more grayish in the photo. Wonder if a custom, dark black leather with white stitching could be made to match the Limited trim?
Would love to hear your feedback if you purchased & installed one of these.
