Blind Spot Monitoring with 5th Wheel
As sort of mentioned above, trailer blind spot monitoring is a 2020 only feature, and only supports conventional trailers. If you select “Goose/Fifth Wheel” it disables it
My 2021 has it.
As sort of mentioned above, trailer blind spot monitoring is a 2020 only feature, and only supports conventional trailers. If you select “Goose/Fifth Wheel” it disables it.
My 2021 has it.
2022 has it . Manual explains
Guys, the post you're quoting was made in 2020 and should be taken in that context.
To phrase it correctly in the current time-space continuum, BSM is a 2020+ thing.
I have a 2020 2500 Cummings and I tow a 30ft 5th wheel, I select conventional and it works. I don't think it kicks in until the other vehicle is close to the truck blind spot, but thats good enough for me.
Thanks for the assist. I haven't been here in a while. (Off topic warning) Looks like I'll be coming back though. Even after running the numbers best I could for weeks it turns out my new travel trailer is actually too heavy for my Gladiator, so as much as I love the thing it's going to have to get traded in for another HD. Wish I'd just kept the '20 in the first place, but I guess now I'll get to order a '23 with all the new toys.
So...Is the BSM still disabled when towing a gooseneck of fifth wheel for the 23's?
No one has a '23 yet so it's hard to say for certain, but since the sensors haven't moved it's unlikely there will be any change.
When towing my 5 th wheel l found when l put it on conventional it will work . Not all the way back but about 20 ft . My 5 th wheel is 96 “ so it may not work on a 102 wide
Works with my GN...it does have a limit of 39 ft iirc .....so if yours is longer then it might not....my GN is 32'.....
Perhaps this has been answered already but why the 5th wheel option on the display at all if it won't sense beyond a 30' trailer. Is it an option I missed when I ordered? I don't believe so.
It was in the trailer towing package in 20 . I would think they could have put it on the mirror mounts .
I was thinking/hoping that this feature was integrated into the new mirrors and worked better. Otherwise, for a full time DRW tow vehicle, this seems like a pretty worthless feature. Thoughts?
The option for 5th wheel is specifically to disable it. With the sensors in the taillights they can’t see around (most) 5th wheels.
Putting the sensors in the mirrors would make them even more enormous than they already are, and far more vulnerable to damage.
