How would you go about balancing these without a good balancing machine?Exactly… if you need a tire shop to change your tires on beadlocks you likely dont need the functionality of beadlocks lol
Or we could likely purchase one of the jeep's to check fitment. I may consider this once I have some extra power wagon funds.I’m talking to a machine shop who makes these for the mopar wheels that come on the v8 Jeep Jl. He thinks his may work but need a diameter measurement for the ring Bolt holes. Does anybody have that? I’m out of town at the moment so can’t measure mine. If any one can get that, we may even be able to come up with some sort of group buy.
BeadsHow would you go about balancing these without a good balancing machine?
Counteract beads. That’s what I use. Glassy smooth balancing.How would you go about balancing these without a good balancing machine?
Is there a typical amount of beads/tire size? I've thought about putting beads in my next set of tires cause the tire balancer sucks.....Counteract beads. That’s what I use. Glassy smooth balancing.
Anybody who tells you balancing beads don’t work didn’t have enough weight in their tires (assuming they didn’t have a bad tire/wheel)
Counteract has a good chart to go by. I lean toward the heavy side because I chunk out tire lugs. 14 oz will do 37” MTs. I use the throw-in bags or you can funnel them into the valve stem. They give you a filtered valve core.Is there a typical amount of beads/tire size? I've thought about putting beads in my next set of tires cause the tire balancer sucks.....
Where are you located? I have an extra ring I'm willing to donate for the cause.I’m talking to a machine shop who makes these for the mopar wheels that come on the v8 Jeep Jl. He thinks his may work but need a diameter measurement for the ring Bolt holes. Does anybody have that? I’m out of town at the moment so can’t measure mine. If any one can get that, we may even be able to come up with some sort of group buy.
