B&W 5th Wheel Hitch Problem
mcspeed
Jan 25, 2021
Did you loosen the 8 bolts as explained in the post #13video? After watching your video and the other one it looks like the solution. Just curious.
The1adman
Oct 3, 2020
Yes I did, you have to align all 4 pucks. The issue isn't alignment its either one of the 4 truck mounted pucks it to low or high or the 5th wheel hitch base is not level on all 4 corners. There is no adjustment for that. This is why I am being sent a new hitch base. B&W provides shims on the Ford system to adjust for this but do not on the Ram. This is the 3rd one I have had and no issue with the previous 2.
mcspeed
Jan 25, 2021
Thanks, keep us posted on how it goes. Nice that B & W stands behind their product.
RV_Goose
Aug 14, 2020
If this nhitch has worked on ntwo other RM trucks, I'd saw it's this truck bed/mounts that have an issue.
Have you tried putting a square or level on the truck bed to see if it is tweaked?
The1adman
Oct 3, 2020
Unfortunately its not the same hitch otherwise I could definitively say its the truck. This is a brand new hitch I picked up Saturday. I have used a caliper to measure from top of puck to bed and they are all the same. Not sure that the bed is a very good place to measure to though.
The bed does not matter and it sits on the pucks only not on the bed at all
