AUX Tank Installation Prices
HopFanatik
Feb 11, 2021
Everett, WA
I've been looking around for AUX tanks & installation quotes.
Tanks ranging from RDS gravity combos to TItan Trekker 50s installed on my 2020 3500 CC SB. The install quotes I'm getting back from some places range from $600 to $800 before taxes, hazardous material fees, etc. Does this seem high to anyone else?
Anyone in the PNW got a shop they'd recommend?
Cheers,
Andrew
OuachitaAdventure
Jul 3, 2019
Those prices are ridiculous. I don't have one myself, but several friends have had local shops here do them between 200-250. Doesn't help you in the PNW, but just a reference.
Thats not bad actually considering that would
be a tank the filler neck float valve and labour....
there is no chance your even buying a tank for 250
Rappr
Cheers,
Andrew
I installed my RDS 91 gallon gravity feed aux tank in about 2 hours. Measure twice and cut/drill once and you’ll have zero issues.
Now that I have done one, I could probably do it in an hour
Mind snapping a picture where you put the valve in the filler neck
Rappr
You won’t get much out of the photo. I took the hose clamp off of the fuel pipe and vent. Remove the screws that hold the fuel/DEF filler port in place. Do NOT disconnect any of the DEF lines. Maneuver the fuel pipe out of the rubber boot by the fuel tank. Using the RDS valve as a template, cut off the metal filler pipe. I used a hacksaw. Make absolutely sure you clean out any metal shavings! Insert one end of the valve into the rubber boot going to the fuel tank and use one of the kit provided boots to tie the other end of the valve into the pipe you cut off. Reinstall everything and hook up the hose coming from your RDS fuel tank into the valve.
Nick
Mar 14, 2020
Cheers,
Andrew
Nick
Mar 14, 2020
That seems high I had quotes of 4 to 450 on a Titan 50 . That hazmat is BS . My son installed it for free . There is a good Titan Video on self install . I put the pump and filter in the bed near the tank . crawling under the frame to change or fix was something I did't want to do . Tita has a list of installers which covers most areas . Check it out .
thats what i was planning to do so i guess i will continue as planned thanks
Jacob
Nov 3, 2020
If you have a dually you probably have a lot of room to work in there. Mine was a single wheel. It only takes a few seconds to disconnect the def lines and pull the whole thing out.
Good to know i am only a 2500 next time i have a chance to put it on the hoist ill have to do it
Untillater
Apr 12, 2021
why cut the metal filler neck pipe when you can just cut the rubber hose near the tank?
The valve needs to be as close to 90* as possible on the horizontal plane to function effectively
Untillater
Apr 12, 2021
Thats interesting, the same roll over valve on my rds tank is mounted flat on the top. IE horizontal plane.
I went with cutting the rubber hose, will see if it has any leaks / issues. So far so good though.
