Atty
Yep, the Aux switch block I bought was 68376644AE (got the part number from this website) it's for the diesel, has exhaust brake switch, tow/haul and front /rear park switches as well as the 6 Aux switches). The best place to locate the relays will be in the Aux PDC box just aft of the driver's side battery (already has the cabin diesel heaters relays in there). You'll also need fuses etc. The relays and fuses aren't generic off the shelf but are common in RAMS etc. I found the part numbers for fuse and relays in this thread too. You will need to use AlfaOBD (or something similar) and have an OBDII reader ( I already had one from other vehicles) and a security bypass module (bought mine from infotainment) it's a bugger to get to but they have a video showing how to do it. I have done it a few times now and gotten very quick at it.So the switch ad relay are 2 separate part numbers?
