12V Automotive Fuse and Relay Box, with Pre-Wires, Fuse Relay Block, Universal Fuse Block and Relay Kit for Cars Trucks Marine Boat https://a.co/d/dvmP8RU
I went with the aftermarket relay box and wiring kit from 4wheelelectronics. Worked great. Super easy install. I have a gasser. I think the diesels come with a PDC already installed.Following what @Jimmy07 said, I took the time to locate my exact year and trim on Autotrader, which had the aux switches from the factory, as well as bill descent and other bells. It was essentially a fully loaded 21 Longhorn 2500 Diesel. The aux part number my local CDJR gave me differed vastly from the decoder ring posted earlier in this thread, so be mindful of that.
If I’m looking at the mopar kit above, it looks like it comes with the leads that are missing through the fire block, you just omit the leads that stop halfway and swap out with the leads shown in the install manual under A2. Perhaps I’m missing something.
What I’d like to know is if it’s worth the $380 for the PDC if I can get something like this on Amazon for $27 and it keeps my connections in the cab where I need them? I say like this… I’ll likely go the Eaton/Bussman route but still…?
Yes you do have one all diesels have it because its the cabin heater relay/fuse PDC aswellYeah I don’t have the PDC on my truck unfortunately. It is a diesel. I’ve looked under the hood 4x expecting to find something different but I cannot locate them. $400 is twice the cost of the finished, polished switches. So I guess I’m just struggling with that part. $100 a switch from a macro perspective isn’t all that bad, if it’s done factory.
There is no harness you can buy you have to piece it together.Almost positive you can simply add the OEM harness with the terminal to plug wires into.
They are not molex connectors you can use them if you wish though, there is a thread here somewhere that outlined wiring up the PDC for aux switchesHere is a photo of my PDC. So the box is here, but the molex leads are not. Did I by chance miss a different thread on here that covers adding just the molex parts to the PDC? Thank you!
Checkout Harrison’s garage on YT. He has a great write up on adding them. I did similar except I built a jumper harness so that I didn’t have to tap into the factory plug behind the switch bank.
Honestly it’s 10000x easier than it looks. I did a write up on making the harness. Just search my threads. Also there was someone on here selling a kit to wire it up if you don’t want build your own.
Hardest part will be finding the switch bank instock.
There’s a wiring diagram on my thread as well.
Personally I like the factory setup. The commercial menu is nice as well. That’s why I went the route I did.
I found one with the Snow Chief Pkg (aux buttons) AND the 8.4 smaller screen. I got to keep all my analog climate control and "toggles" and get the Aux buttons... I appear to be in the distinct minority, but I prefer the 8.4 screen.If you get get the aux switches, you lose the toggles and get two rows of buttons. At least from the photos that have been shown.
Is Last State not saving also an issue with the HDs, just like the 1500’s? Just installed everything and everything works except Last State is not saving after leaving switches on.
I found this in my owners manual. It might help point you in the right direction to adjust your switch settings.Is Last State not saving also an issue with the HDs, just like the 1500’s? Just installed everything and everything works except Last State is not saving after leaving switches on.
