Anyone running a 295/65/20 on stock suspension?
Arth
Jul 15, 2021
how do you like those tires? I had ridge grapplers in my tundra and loved them. do you feel the truck any different? thanks! the truck looks great btw!
Thanks!
Well the obvious stuff is these tires are a lot heavier. The normal 1 MPG loss is definitely there. Traction is much much better than the stock tires. I currently have these aired down until I tow heavy and they have responded very well.
They've got some noise above 45 but nothing crazy. My Cooper zeon LTZs were much louder than these.
Considered the ridge grapplers but went with the recons because of the mileage warranty and the better price at the time.
Overall very pleased!
Joe_Lee
Mar 16, 2023
Spanish Fort, AL
Bumping this thread, can anyone confirm that with 295/65R20s (ridge grapplers or similar) AND the Thuren high clearance sway bar that there is no rub at all?
I originally bought 35/12.5R20 ridge graps last week but they rub slightly on the radius arms, no big deal really but since my wife wants a set of 35s for her Jeep, I'm putting them on hers and I have ordered 295/65r20 ridge graps. I don't mind buying the high clearance sway bar, so just asking for clarity.
G Mcpherson
Dec 20, 2020
Yacolt, Wa
The Sway Bar is designed to Clear. Most likely you will have Rub on the Radius arms unless installed on After market offset wheels. + 18 or more.
Ramcat
Oct 22, 2021
I’ve got this set up and still rub slightly on radius arms. It leaves a little rub mark but I cannot feel it when turning full lock.
Joe_Lee
Mar 16, 2023
Spanish Fort, AL
Ok the current 35/12.5s rub on the radius arms slightly so I was hoping the 295s (11.77”) would not rub. I guess the only way to ensure no rub on the radius arms is to go to a 285/65r20?
Joe_Lee
Mar 16, 2023
Spanish Fort, AL
Thanks guys, sounds like running stock 20s with anything larger than the factory size results in minor rubbing. I think I’ll upgrade to the Thuren high clearance sway bar and just live with the minor rub on the radius arms. I know I’m likely in the minority but I really like the stock 20” wheels on my truck.
Razorschaos
Feb 15, 2023
I’m looking at the 295/65/20 ridge grapplers as well. I’m on stock suspension on my 2500 but looking at getting new wheels as well instead of the NE wheels. I’m looking at 20x10 wheels with a -18 offset. I’m assuming I will run somewhere even with the offset. I’d love to do the thuren 2/1 lift since I prefer some rake with the sway bar but at another $3K, I’m considering doing the 295/65/20 versus getting the lift and running 35x12.5s.
Also, I don’t have the off-road suspension.
dddoug
Jun 10, 2021
I'm running a BFG K02 295/65/20 on stock rims with 1" wheel spacers. No rubbing on anything.
dddoug
Jun 10, 2021
What kind of spacers are you running? Any way you can share a pic of how much poke you're getting with the spacers?
Bought used alum. spacers local. See pic-
jrf
Mar 27, 2023
Did you try those without the spacers first? If so where did they rub?
I like the look of this and also having a really hard time finding spacers.
Personally I would want to keep a hub centric spacers and I did find these:
not cheap though. Anyone else go this route?
Ostracize
Nov 29, 2020
Right behind you
Not him but I run the same size tire.. Rub is on the radius arms and sway bar.
I don't run spacers... Some do, I do not. Just installed a thuren setup with high clearence radius and sway bar with leveled springs new shocks ... Way more than spacers but no more rub. But my plan is once these tires are done going new 20x9 wheels with 35x12.5 tires. This setup can technically handle 37s depending on tire and backspacing. 37s aren't for me.
dddoug
Jun 10, 2021
No, didn't try without the spacers. I wanted sidewalls even with factory fender flare. This is close.
Those spacers look like mine. Note - I had to use a cut off wheel to shorten factory studs. a 1" or 11/2" spacers will require to cut factory studs. Studs will hit back side of the factory wheel.
  • Like
Reactions: jrf
Neil
May 14, 2021
2019 Ram leveled with stock laramie wheels… would a 295/65/20 rub?
Ewoodard
Apr 5, 2021
Mine rub slightly at full lock on passenger side track bar and radius arm. Toyo Open Country R/T Trails.
