Surf2snow1
- Joined
- May 6, 2021
That’s my issue with the Toyo’s :/Nothing on the Radius Arms?
how do you like those tires? I had ridge grapplers in my tundra and loved them. do you feel the truck any different? thanks! the truck looks great btw!
Thanks!how do you like those tires? I had ridge grapplers in my tundra and loved them. do you feel the truck any different? thanks! the truck looks great btw!
My 285-65-20 Rubbed with Stock wheels on the Arms.
I'm running a BFG K02 295/65/20 on stock rims with 1" wheel spacers. No rubbing on anything.I’m looking at the 295/65/20 ridge grapplers as well. I’m on stock suspension on my 2500 but looking at getting new wheels as well instead of the NE wheels. I’m looking at 20x10 wheels with a -18 offset. I’m assuming I will run somewhere even with the offset. I’d love to do the thuren 2/1 lift since I prefer some rake with the sway bar but at another $3K, I’m considering doing the 295/65/20 versus getting the lift and running 35x12.5s.
Also, I don’t have the off-road suspension.
here is a picI'm running a BFG K02 295/65/20 on stock rims with 1" wheel spacers. No rubbing on anything.
Bought used alum. spacers local. See pic-What kind of spacers are you running? Any way you can share a pic of how much poke you're getting with the spacers?
Did you try those without the spacers first? If so where did they rub?I'm running a BFG K02 295/65/20 on stock rims with 1" wheel spacers. No rubbing on anything.
Not him but I run the same size tire.. Rub is on the radius arms and sway bar.Did you try those without the spacers first? If so where did they rub?
I like the look of this and also having a really hard time finding spacers.
Personally I would want to keep a hub centric spacers and I did find these:
Dodge Ram 2500 3500 8x6.5" Wheel Adapters Hub Centric Billet Aluminum
1994-2022 Dodge Ram 2500 3500 heavy duty hub centric wheel spacers. 8x6.5 bolt pattern with a 121.3 mm hub bore. Custom made in the USA. Safe to tow. Made out of billet aluminum 606. 1" to 4 inches available.venumwheel.com
not cheap though. Anyone else go this route?
No, didn't try without the spacers. I wanted sidewalls even with factory fender flare. This is close.Did you try those without the spacers first? If so where did they rub?
Mine rub slightly at full lock on passenger side track bar and radius arm. Toyo Open Country R/T Trails.2019 Ram leveled with stock laramie wheels… would a 295/65/20 rub?
