Anyone else have the loose shift lever issue? Does it reoccur?
RV_Goose
Aug 14, 2020
On my 2020 RAM 3500 Tradesman 3500 CC LB dually HO Aisin -
I just did a google and found this -
I will tighten mine up today. Anyone else have this? Should I expect this to reoccur? Is it a bad design that will plague this truck.
Bombdigitty
Jan 30, 2021
Prior to ordering a 21' 2500 bighorn i was looking used and test drove a former plow truck. It was a 15' limited longhorn with 90,000 km
Shifter was very loose which had me concerned. One of the reasons i walked away from it. Not the only reason, but one of them.. Had i know it was potentially an easy fix, maybe i would have ended up with it.
MikeXM
Nov 30, 2019
Nah, it's just not torqued properly at the factory for some reason.
Set it once - if yours is loose. Not all shifter are loose from factory.
Just like the fuse box. Assembly robot is not strong enough to push the fuses all in :D
Nope no issues after just like the wiper arm torque
RTillery
Jan 16, 2019
Mine loosened up after a couple of months from new. I snugged it up, It's been good for over 40,000 miles now.
RV_Goose
Aug 14, 2020
Took me longer to get out and return the 10mm wrench than to adjust the nut to tighten up the shift lever. All is good now.
MooneyFWD
Dec 11, 2020
Mine was loose when I purchased (used). Randomly saw that video and tightened it up. I was pretty disappointed with the feel when it was loose, so I'm glad it was an easy fix.
gimmie11s
Mar 30, 2021
Mine has come loose at the ~9000 mile mark. I'll tighten it back up today and add a drop of blue loctite
gen5020
Apr 11, 2020
USA High Sierra - 7200' elevation
I wish I would have found this sooner! Truck was in for a different reason. Dealership told me the shift lever was loose, it was a known issue that needed to be fixed because it could be dangerous. I authorized the repair and they charged me $200 to fix it. Need to check repairs here first!
hexplor1
Oct 1, 2022
Yep, my 2019 had this issue, but a drop of Loctite fixed it right up. My 2022 is nice & tight from new,
flan
Aug 16, 2019
$200! Wtf man that’s a ripoff...
jbncccb
Apr 19, 2020
If under warranty there is a TSB on it. They change the entire assembly out. The replacement isn't supposed to work back loose. Not sure what's different.
Sent from my ONEPLUS A6013 using Tapatalk
MikeXM
Nov 30, 2019
I would come back to them with the TSB and get them to explain the charge.
Don't let them get away with it.
