Tried the cheap plastic levers on the actuators. Rotated them. Zero affect on the locks. One lever just popped off the press fit collars and is loose in my hand. Can't snap it back in. so I'm going in the wrong direction here. The right latch rotated the same way and again zero result in unlatching. I'm wondering if power is needed to have them unlatch even though the video showed no power to unlatch. I 'm pretty much fed up trying anything further with the exception of jumpering 12VDC to each one. As you can probably read I am frustrated with this whole process. I started to remove the top lid of the gate to look down on the actuators but after removing the plastic fittings on the inside there are larger fittings in the top so I was near to make further damage. Maybe a body shop is the best solution. UGH. If I find that critter.....
