AlphaOBD Help
RCMEDIC
Jan 27, 2022
Somewhere along the line (Using the AlphaOBD) I inadvertently disabled the "Auto Headlights" on my 2015 Ram 2500 so that when the headlight switch is in the "Auto" position, it behaves as "OFF" and I must manually turn my headlights on and off. Any idea on how I can correct the problem with my AlphaOBD? The SDcard that I saved data to is apparently corrupt and reading saved data/previous settings is not an option.
Jimmy07
Re-coding from an easy-chair
Apr 5, 2020
VehConfig 3: Auto Headlamp Feature Present- YES
Jimmy07
Apr 5, 2020
Read your BCM system ID, upload it to google drive, and send me a link to it. I’ll take a look at your settings.
MtnRider
Feb 5, 2020
Georgia
Here are some of the auto headlight configurations I could find in my log.
ECU Qualification:
Auto Headlamps Present: Yes
Vehicle Config 3:
Auto Headlamp Feature Present: Set
CBC Exterior Lighting Calibrations:
Auto Headlamp ON Threshold: 3.31 V
Auto Headlamp OFF Threshold: 2.55 V
Analog Inputs:
Headlamp Switch Position: AUTO
Headlamp Switch Voltage: 4.02 V
