I have an Alfa OBD II MX+. Is there anything else that I need to program my truck? I am wanting to add the hill descent control switch on my truck.
Thanks
Alfa OBD Configuration Process to add (Hill Descent Control) to a (5 GEN) 2021 Ram 2500 6.7
Here are the configurations needed in order to Add Hill Descent Control
Go to Line Item: VehConfig 1:
Select: Hill Descent Feature Present:
Select: YES
Go to Line Item: VehConfig 8:
Select: HDC Button Location:
Select: HDC Present in TCSM
(TCSM would be your selection if your Hill Descent Control button is on the panel where 4x4 is located.)
Go to Line Item: ECUConfig 3:
Select: Hill Descent Switch Feature Present:
Select: YES
Caution: Before making changes the first time you need to make a log of your original configuration. Here is the process to make that log.>
1. Connect Alfa OBD via Bluetooth
2. Select: Ram/Dodge
3. Select: Body Computer
4. Select: My 2021
(Yours may be different depending on the year of your truck)
5. Select: Connect
6. Click on Battery Icon on Alfa OBD App.
7. Select: Read System ID
8. Click on Tools Icon on Alfa OBD App.
9. Select: Upload to Google Drive
10. Select: Sign In
11. Select: Upload Faults and Status Log
12. Select: Body Control Module My 2021
The process to connect and add the Hill Descent Control feature:>
4. Select: My 2021
5. Select: Connect
6. Go to Hood Icon
7. Select: Select procedure to start
8. Select: Car configuration changes
9. Go to Line item:
VehConfig 1:
1. Select: Hill Descent Feature Present:
2. Select: YES > Then Select: Start > Then Select Next > Then Select: Start
10. Go to Line item:
VehConfig 8:
1. Select: HDC Button Location:
2. Select: HDC Present in TCSM * > Then Select: Start > Then Select Next > Then Select: Start
*(TCSM would be your selection if your Hill Descent Control button is on the panel where 4x4 is located.)
11. Go to line item:
ECUConfig 3:
1. Select: Hill Descent Switch Feature Present:
12. Click on Battery Icon on Alfa OBD App.
13. Select: Read System ID
14. Click on Tools Icon on Alfa OBD App.
15. Select: Upload to Google Drive
16. Select: Sign In
17. Select: Upload Faults and Status Log
18. Select: Body Control Module My 2021
19. Click on Key Icon on Alfa OBD App
20. Select: Disconnect
21. Cycle key on and off for 30 sec.
22. Leave the vehicle for 5 minutes before trying the feature out.
