ironmike
Does anyone have experience with PPE thermal bypass cooler valve & PPE transmission Pan? Any insight or recommendations are appreciated!
I am seeing 160-180 transmission temps with various unloaded uasage. Will i see a dramatic temp drop or what has been the experiences with these upgrades?Yup....works great....my recommendation is to put both on your truck....
Expect 130- 140....I am seeing 160-180 transmission temps with various unloaded uasage. Will i see a dramatic temp drop or what has been the experiences with these upgrades?
That is significant!! Thx!!Expect 130- 140....
Same thoughts... But i keep hearing the fail possibilities of the stock bypass, when it locks up, you are screwed... this new bypass won't lock up. & as afar as cooling, Seems cooler may prolong transmission parts & fluid? And as far as towing hard, wouldn't we benefit from the cooling capabilities with more efficient cooling?Curious what you’re looking for here, isn’t recommended operating temp on the Aisin like 160-180? Genuinely asking.
Understood. I may be less informed but im unaware of the stock bypass failing on the AISIN. Even when towing and pushing my truck hard i've never seen my trans go above 176*.Same thoughts... But i keep hearing the fail possibilities of the stock bypass, when it locks up, you are screwed... this new bypass won't lock up. & as afar as cooling, Seems cooler may prolong transmission parts & fluid? And as far as towing hard, wouldn't we benefit from the cooling capabilities with more efficient cooling?
100% agree.. yes towing temps I’ve seen go over 225 with 30’ Magic powerboat & vaca gear loaded, through Arizona in summer… not at all comfortable with that. If there’s a way to mitigate, why not.. also same, there should be no reason thermal bypass becoming stuck closed, but this removes that possibility it states. Cheap precautionary insurance.. lolUnderstood. I may be less informed but im unaware of the stock bypass failing on the AISIN. Even when towing and pushing my truck hard i've never seen my trans go above 176*.
I also dont think cooler is always better. If you're running hot and not within the right operating window then yes increased cooling capability makes sense, but cooling below that probably has adverse effects. Just my $.02
Are you seeing your trans often going above 180 and into the 200s?
Makes sense, that is hot so I dont blame you for seeking out options. Appreciate the insights.100% agree.. yes towing temps I’ve seen go over 225 with 30’ Magic powerboat & vaca gear loaded, through Arizona in summer… not at all comfortable with that. If there’s a way to mitigate, why not.. also same, there should be no reason thermal bypass becoming stuck closed, but this removes that possibility it states. Cheap precautionary insurance.. lol
Your truck will struggle to use 6th in the winter as temps will be to low to allow it to shift. Thats a product for the desert not anywhere that gets snowI am seeing 160-180 transmission temps with various unloaded uasage. Will i see a dramatic temp drop or what has been the experiences with these upgrades?
Cuz we all live in Canada....you're statement is false ...Your truck will struggle to use 6th in the winter as temps will be to low to allow it to shift. Thats a product for the desert not anywhere that gets snow
Your right the old trucks did not have t stats in the trans and most of the winter we had no OD in the extreme cold…. There are plenty of US states that see cold or are you oblivious to that….You guys that think these trucks need one of these thermal bypass blocks know that that only started using them in hd trucks in 2013 right? So how on earth did the trucks before that ever make it with out one? And for those that think the fluid being too cold causes adverse effects ....do you idle your truck until it reaches 165 to start driving?
Yeah bud....I'm oblivious to cold US states....can you explain which states are cold and which states aren't? As I said before....we don't all live in Canada or Alaska...the bypass works fine for us lower 48 people...Your right the old trucks did not have t stats in the trans and most of the winter we had no OD in the extreme cold…. There are plenty of US states that see cold or are you oblivious to that….
And the statement is true i know a couple of people who had the bypass and then removed them in the winter due to no OD in temps below -20°C
Really ill explain that to my friend in Minnesota and tell him to put his bypass back it because someone on the internet said the lower 48 cant have the issues he was having……Yeah bud....I'm oblivious to cold US states....can you explain which states are cold and which states aren't? As I said before....we don't all live in Canada or Alaska...the bypass works fine for us lower 48 people...
