Airlift compressor and shrader valves
Buck81
Oct 1, 2021
New to the site and couldn’t find anything pertains to my topic.
I recently bought a used 2018 2500 and found both a working Airlift compressor (16092) and 2 shrader valves connecting to the airbags.
Just trying to understand the why behind it. Maybe a backup in case the pump dies out?
Thanks in advance!
Fishnerd
Jun 29, 2021
More than likely, I put shrader valves on mine even though i have a compressor for auto fill, primarily for redundancy. Its joined with a T connector but I also but a “shut of valve” to isolate from the main line, otherwise the shrader would be useless.
Chris1911
Nov 28, 2019
Georgia, USA
The airbags come with the valves in the box. The compressor is sold separately. The valves can be used to pump them up manually, if the compressor goes bad.
LateToTheParty
Didn't want to come
Jul 29, 2020
Roxborough, CO
Maybe they installed initially using the schrader valves, but then added the compressor later and just didn't remove the original setup.
My thought exactly…. They probably realized after a few times manually airing them up every time sucks and put a compressor on the system
Nick
Mar 14, 2020
Thats what they are . Had those on my last truck.
