Air Horns!
44Dan44
Nov 27, 2022
Maryland
I'm sure it can be done, but could one of the Aux Upfitter switches be used as a toggle to switch between running the factory horns on the factory switch and Air horns on the factory switch? Like say I have Aux 6 setup so when it's on I'm running the air horns, but say I don't want the triple honk to scare the crap out of people in a parking lot when i leave my truck running for my dog I can turn it off and it'll use the factory horn.
I don't have the answer, but what if the kernel of your idea "cracks the code" of the triple honk? At least for people with Aux switches, you'll be renowned the world over, discussed over camp fires, "yeah, thanks for noticing, I used the Goofy Solution" :cool: Ya never know.
For now...for the dogs...I guess the fob against the rear window thing works.
mountainears
Mar 29, 2022
That is how I solved the triple honk on my truck. We’ll kind of, I was going to use the Aux switch but instead I used the VSIM and a relay which switches the horn trigger when the truck is running to the VSIM horn button output. Triple honk issue is gone. It’s a little bit of work but that issue has been behind me for some time.
Scalper
Apr 19, 2023
I plan to get one of the electric air horns and try this but I think I'd just rather keep the stock horn off and use the air horn.
Herrred
Apr 29, 2021
I have Kleinn RAMHD-230 onboard Air and Train Horn system on my 21 3500. It's hooked into my Aux Switches. Very loud, so I use the horns sparingly. I use the air all the time for the truck and my fifth wheel.
Alenbaarz
Nov 15, 2023
Ugh, distracted drivers are the worst! For a horn that'll cut through the phone chatter, consider powerful air horns. Not quite train horns, but still attention-grabbing. Check out https://bosshorn.com for some solid options. Stay safe out there and may your horns keep the distracted ones in check!
CFE
Jan 3, 2022
call me stupid - but aren't they essentially the same in function?
zerogravity779
Mar 24, 2023
TN
Working on mounting and wiring right now but tested one out today on a bench power supply. I am IMPRESSED! Made me wonder if I should just mount one of them, nawwwwwwwww. ;) Will follow up again.
Highly recommend.
Any update on the horns? Install and impressions etc.
