Aftermarket front recovery points for stock bumper.
Ck88
Mar 15, 2023
Any suggestions for aftermarket front recovery points? (I will continue to use stock bumper)
Greenhills
Mar 11, 2021
Canada, Alberta
Front tow hooks are more than sufficient and very strong.
Otherwise you are looking at something mounted underneath and the lower valance will likely interfere.
I would try and find some OEM tow hooks and install them as any aftermarket will likely be part of an after market bumper
Ck88
Mar 15, 2023
Many thanks/ agree on strength / just wanted something that sticks out more
44Dan44
Nov 27, 2022
Maryland
He has a 4th gen id assume because its in the 4th gen section but also they are not safe to use as a recovery point they have very low weight rating
Didn't notice 4th gen thanks, he also said use bumper....I'd take this over that as recovery point any day lol.
LateToTheParty
Didn't want to come
Jul 29, 2020
Roxborough, CO
Ck88
Mar 15, 2023
Before I replaced the bumper on my 4th gen, I'd installed some replacement tow hooks similar to these, as the prior owner had replaced OEM hooks with a LED bar that took up the whole lower opening:
This is what i am looking for; something that sticks out further than the stock recovery points - thank you!
Ck88
Mar 15, 2023
Appreciate the help / never said i would use bumper as recovery point just to be clear
Ck88
Mar 15, 2023
Found something suitable - at least i can now attach a recovery strap via shackles
Ck88
Mar 15, 2023
