So I have been searching for a while and cannot find much information on this, basically using the CC rear mounted tank circuits to control my auxiliary tank transfer into the truck.
Why? you can enable the dual tank option in Alfaobd and get a "factory" fuel gauge in dash. let the truck auto transfer when needed as designed from the factory.
**I will try to update this post as I go, and as information is gathered**
Known information:
C1/A pin 16 has the connector for the fuel transfer relay.
C5/E pin 17 connection for fuel level sensor tank 2
both need Kostal 32124734123000-L terminals
18awg wire needed for BCM to PDC (factory wire is pink)
BCM C1/A 16 runs to PDC C6 pin 16 and needs a Yazaki 7116-4780-02 terminal
PDC C6 pin 20 is output to transfer pump and needs a Yazaki 7116-4270-02 terminal
AlfaOBD:
VehConfig 3: Two Fuel Sending Units Present / "YES"
ECUConfig 4: Secondary Fuel Tank Capacity / "197 L/208 L"
CBC Config I/O: Fuel Transfer ON/OFF Relay Control - Pin A16 / "will update when verify"
Unknown information:
ohms of sender unit (Should be 0-90 ohm, will verify once I get wires installed.)
I don't care too much about correct DTE calculating off the two tanks, especially since factory is a 52 gallon tank, and my tank is over twice that. having a factory gauge without "pods" or other junk would be great.
Known information:
AlfaOBD:
