Bumping this up as I've pulled part numbers up for my VIN (2022 Laramie LH) without adaptive cruise and a random VIN with ACC but the parts list has the same part numbers listed for both vehicles. Anyone have a way to decipher which part numbers are needed to add ACC?
This is everything needed to add ACC:
-Rear view mirror adapter- 68338659AA
-Lower mirror cover- 6PA25TX7AA
-Upper mirror cover- 6PA26TX7AA
-(3) DASM mounting nuts- 6509581AA
-Windshield (or equivalent aftermarket part number)- 68362490AB
-Adaptive cruise steering wheel switch- 68365332AC
-DASM/mirror harness (without cab lights)- 68517603AA
-DASM/mirror harness (with cab lights)- 68517609AA
-DASM- The part number is different for each model year, and so far, a used DASM can not be used. I’m in the middle of testing whether it matters which model year part number is used, and a viable solution to clear the original VIN out of a used one so it can be a cheaper retrofit. ***EDIT*** A used DASM can be used. Instructions for dealership tech below***
2019- 56029825AG (I’m not sure if this one is capable of lane assist)
2020- 68454269AG (I’m not sure if this one is capable of lane assist)
2020- 68462656AF
2021- 68484693AD
2022- 04672894AB
When you get the windshield installed, MAKE SURE to have them remove any charges for reinstalling sensors, or calibrating sensors.
You will be installing the DASM yourself, and you’ll have to have the dealership run the calibration. Safelite, or any window installer that uses asTech software (most do) are not capable of taking the new DASM out of plant mode for the calibration. Plus, they charge about $450 for the calibration.
**Sidenote for anyone that already has ACC, FCW, etc that needs windshield replacement, and is paying out of pocket**
Do not let the windshield installer calibrate the DASM, and have them remove any charges for it. It is absolutely not necessary to recalibrate a Ram DASM that was already calibrated before, and hasn’t had the adjustment screw physically adjusted.
***This is what you need to tell the dealership tech to do if using a used DASM:
1) Perform the “Enter Plant Mode” function:
2) Clear all DTCs. This will get rid of the vehicle configuration mismatch fault so the calibration will run.
3) Run the auto alignment procedure like they normally would:
