ac problems
moshez333
Aug 30, 2019
hi
i saw a few post
can someone please check the
tamp in the middle near the screen
i checked 13.5c
the ac sensors is on 2c near the vent ..
help im hot ...
Albert193500
Sep 15, 2019
U S A
hi
i saw a few post
i checked 13.5c
help im hot ...
I'm at 54 degrees. Well I was before the dealer touched it, now I'm near 60 degrees when moving.
jeff
Mar 7, 2019
I'm not ordering a 2500/3500 until they figure this AC problem out!
Albert193500
Sep 15, 2019
U S A
As of now I guess I'm one of the first to get this HVAC box, from what I was told by the dealer it is a different part number than what was in the truck when built. See my thread for updates. It is currently at the dealership.
IronByron
Aug 17, 2019
Central Indiana
AC issues are not universal across the board. My 2019 2500 (6.7) has zero AC issues (in temps up to 95 degrees and high humidity). I feel for the folks having issues but I don’t think it’s fair to say the majority of these vehicles are defective. Just giving perspective from someone not having an issue which you typically don’t hear about.
Albert193500
Sep 15, 2019
U S A
Out of curiosity, do you have any air at all coming from your defrost when in any mode, mainly vent? It's notable huge amount but enough to cause a problem. The temp issue is not as big as the flow issue.
Albert193500
Sep 15, 2019
U S A
Not that I can detect.
You are very lucky. I have checked about 18 trucks and all do it. The most noticeable is when you put it in foot only it sends about half the air up to the defrost and less as you blend through the other modes. I wish I could see what's different on your truck lol. A friend just checked a 2020 1500 and is doing it.
IronByron
Aug 17, 2019
Central Indiana
Can’t say I have ever put it in foot only. I can try that specific mode and see next drive.
Albert193500
Sep 15, 2019
U S A
That's the issue, it's when in a humid climate. I am in central Florida and every evening is rough on this issue
Gondul
Prince of Pintops
Mar 10, 2019
Same... this summer sucked when I had to take the truck to work. Opening the windows the for the first several minutes to vent out the hot air helped but it still wasn't cold 30 minutes later when I got home.
IronByron
Aug 17, 2019
Central Indiana
I hear most people complaining about air not being cold enough. I live in a humid climate as well. Not sure what you mean. Also I dont ever have AC on my feet only so issue wouldn’t be there unless I did that. I have never had my front windshield fog from an ac leak either.
Albert193500
Sep 15, 2019
U S A
You are lucky. The cold issue seems to be the temp door issue, I'm pretty sure anyway. That fogging issue happens at idle or driving in the evening through early morning. The loaner im in now does it in 87 degree middle of the day heat at idle
jeff
Mar 7, 2019
thanks!
jakalafus
Apr 27, 2019
How does it do in the summer? I just got mine and travel to Havasu a lot. I’m getting worried about this season.
Sadly not well. After 105 it’s really bad. My dealer says that it’s a common complaint but no TSB yet.
