68RFE maintence
oledirteh
Feb 14, 2024
Union Bridge MD
Good morning,
Currently prepping to do a transmission fluid change and flush of my 2021 ram 2500 bighorn 6.7 with the 68RFE
Just want to Confirm that these are the following part numbers i should be looking for,
Transmission pan gasket - FEL-PRO TOS 18733
Transmission Filter - Mopar Transmission Filter 5013470AE
Transfluid - AMSOIL SIGNATURE SERIES MULTI-VEHICLE 100% SYNTHETIC AUTOMATIC TRANSMISSION FLUID
Also, for the Transfercase i can use the same as the trans fluid wise right?
Thanks for the help, and suggestions.
moparfan06
Mar 26, 2021
Hicksville, OH
Good morning,
That fluid is not correct for the 68RFE. According to https://amsoilcontent.com/ams/lit/databulletins/g3110.pdf that fluid crosses to Mopar part number 68157995AA. That is for the 8 and 9 speed transmissions. I know that Amoil says "AMSOIL warrants the use of this product for Chrysler ATF+4 ® applications above -38°F."
I take that statement to mean that its not certified by FCA to meet the spec for ATF+4. I know that the Napa ATF+4 is certified by FCA to meet the spec.
You’re reading that bulletin wrong, the fuel-efficient multi-vehicle synthetic is not rated ATF+4, but the multi-vehicle ATF has ATF+4 on the bottle.
Also, the -38°F comment is for a different Amsoil transmission fluid, not the signature series ATF.
Trash Panda
Dec 24, 2023
Two filters in the 68, make sure you get both, and buy the metal threaded nipple for the spin on filter. The stock one is plastic junk.
oledirteh
Feb 14, 2024
Union Bridge MD
yea i read that. i found a kit online that has both.
so i might skip this service, back when i had like 45k miles on the truck i went to trade it in for a 3500 HO but they said there was a active code for something in the transmission that calls for a repair/replace. confirmed it at my home dealer and id have never known as there was no dash lights or issues. i didnt have time to mess with it since it was offroad season so never touched it. now at 88k had it rechecked yesterday and still there, so dropping it off on the 26th for them to fix under warranty so im hoping they have to change the oil anyhow :) will see.
