- Joined
- Oct 5, 2021
Do passive regens show up on the DPF screen? I have been monitoring it for a couple of months. I did note an active regen at around 500 miles at around 40% just running around town. The DPF gauge was at 0 when I started my trip. I towed a heavy 5th wheel 1700 miles over 35 hours, mostly interstate. The gauge never moved off 0 and I never noticed a passive regen. No active regen either but didn't expect to see one towing the fiver. BTW I am using a WIX air filter with NO glue strips.
The only indication of a passive regen is the DPF gauge reduces without an “active regen” message.
With a monitor, like the CTS3, you can see passive regen on the regen % PID (sometimes, depends on soot loading and time since last active regen), as well as with EGT3 temp (temp exiting DPF).
Towing the 5th wheel will reduce the chance of a soot loading based active regen, but it won’t have any effect on the 24 hour regen.
