2025 Ram Heavy Duty To Get New ZF Powerline® 8-Speed
LegendaryLawman
Legendary Pessimist
Oct 20, 2022
Definitely.
The knob shifter makes sense and will likely be the choice they go with. It’s readily available and also cleans up the dash and interior. No more rubber boots to wear out and no loose 10mm bolt causing a loose shifter.
As you already know, I’ll pass ;)
Definitely.
Rental car this week, Hyundai Sonata, has a little stubby column "shifter" that just twists back and forth. Nearly as dumb as some of the dash mounted push buttons or levers like Lincoln and anything else with a mini-van-ish sloped dash. Only saving grace is it self parks when you push the ignition button.
Personally, I wouldn't really have a problem with the current knob setup, have used it on some rentals and it does just fine. I would miss the tactile feedback from the leather column shift knob...
mbarber84
Sep 10, 2021
Washington County, PA
Check out the column shifter PACCAR is using in the trucks equipped with the TX-8 (ZF-Powerline)
Not sure if that’s actually a PACCAR product, or if it’s a rebranded ZF component the same as the transmission itself.
This thing is hideous and just plain weird to use.
I’m not the biggest fan of knob shifters, but that’s really not much different than what we have now.
What I really want back is a manual transfer case lever. I shift in and out of 4wd all the time on dirt roads and find the electronic transfer case annoying and slow, I also don’t trust it’ll last very long with constant use.
LegendaryLawman
Legendary Pessimist
Oct 20, 2022
I’ll agree with you that I’ll miss my old t case shifter in my 3rd gen ram. The 2nd gen was kinda weird with the vacuum issues and with high miles they would rattle a lot
Grateful Dad
Aug 21, 2021
Georgia
I actually liked having the manual lever tcase in my Tradesman though you still have to wait on the CAD to shift
If I had a manual transfer case I’d want a manual CAD switch to leave it locked on all the back roads for quicker in and out of 4wd.
jsalbre
Oct 29, 2019
ID
I’ve never seen a manual CAD shifter, but you can buy a one piece axle shaft and eliminate the CAD altogether.
Yeah that’s an option too.
BD has their 2Lo kit, so I figure you could reverse engineer it to keep it locked instead of unlocked.
jsalbre
Oct 29, 2019
ID
Hmm, that’s an interesting idea.
gimmie11s
Mar 30, 2021
Our new Peterbuilt Cummins x15 equipped trucks have this exact shifter.
It's weird.
Nothotdog
May 15, 2023
Massachusetts
Thought I'd share a video with a diesel mechanic's thoughts. He seems to have fairly reasonable points (but I'm not well versed in any of this)
