2022 Ram 3500 Headlamp assembly relay location?
Cam1111
Feb 13, 2022
Can anyone advise on the location of the right headlight assembly relay location?
I cracked/broke the front of the headlamp assembly (they’re back-ordered…go figure). Initially it still worked, but after driving through a rainstorm I lost all functions (low/high beams and turn signal). Figured I likely blew the relay (feedback here is welcome?) and wanted to get it replaced and seal the break up until I can get the new headlamp assembly. Unfortunately I cannot seem to locate the relay (I don’t think it’s a fuse)? Any guidance is greatly appreciated…thx, Cam
superjoe83
Jan 24, 2022
The Headlamp power is fed directly from the BCM, if they are LED lights there is a driver module in the bottom of the headlight that could have gotten wet and is causing some of your problems
EDIT: I see you have limited lights, so yes, any moisture in the lights will likely cause problems
AH64ID
Moderator
Oct 5, 2021
Relays don’t blow, fuses do.
Are any any lights not working?
superjoe83
Jan 24, 2022
Here is the diagram FYI
As you can see, no relays or fuses directly related to the headlights
  • Headlight.PDF
Cam1111
Feb 13, 2022
Nothing is working in the headlight assembly (right)…left headlight assembly is fully functional. No other lighting/electrical issues (that I’m aware of)
Bluedevilman
May 28, 2021
Hey man I was trying to download that PDF and it's not letting me. Could you Dm me a copy please I'm working on my passenger headlight looking for a pin out to trace my turn signal that stopped working.
Sent from my SM-S908U using Tapatalk
Rotty4910
Jan 13, 2024
Did you ever figure out what was causing the issue with the headlight not working? I'm having the same issue and I even replaced the whole headlight assembly.
