2022 ram 3500 EOH brake issue/hot wire issue
Korey killian
Sep 2, 2023
Good morning guys.
I’m stumped now
Got a 2022 ram 3500 i use it to hot shot.
I had a 40 foot big Tex that worked decent with the brakes.
Now a 44ft diamond c with eoh
Everything on all the trailers i tow have worked.
Trailer brakes trailer lights all the signals
including all the generators that i tow
Now i have a brand new trailer with EOH disc brake
So what I’ve checked and came to conclusion
The fuses f30 i switched for another 30 amp
All the other fuses that have trl i checked.
In screen i changed to eoh heavy
Now I’m getting 6.5 volts on the hot at the bumper plug
9.5 volts at the bed plug. (Which i know is the issue) hooked up a 2014 jeep Cherokee and was able to get my trailer pump to turn on (hot wire is at 13.6 volts) integrated brake control also.
Now the volts gain from bumper to bed is confusing me.
I have an appointment with my dealer tech Tuesday but he doesn’t seem to thrilled to search for a short.
Has any one had this similar issue what was your fix?
I will be putting the truck on a lift this afternoon to get a better look at the harness.
CdnHO
Nov 17, 2020
Ontario
What brand is the brake pump? I have Dexter on fifth wheel and no issues.
PrescottNorm
Mar 20, 2020
Dexter Brakerite EHB Actuator, had to install the adapter for low speed braking 0 - 25 mph with Ram OEM brake controller
CdnHO
Nov 17, 2020
Ontario
My pump is a Dexter EH-1600 so that might be why I don't seem to have any issues. Your link appears the adaptor is for Ford and GM vehicles. Doesn't mention Ram. However the OP mentioned a voltage difference when measured at the bed plug and bumper plug which makes no sense. Since it is a new truck, corrosion is unlikely. OP does your truck indicate a trailer is connected?
PrescottNorm
Mar 20, 2020
I purchased my 5th Wheel disc brake system from Performance Trailer Braking in Norman, OK. Yes, adapter states Ford/GM, but Performance stating it would solve my issue with newer RAM OEM controller, which it did.
CdnHO
Nov 17, 2020
Ontario
So you had no brakes at low speeds only? Are you set at "Heavy over Hydraulic"? Were brakes OK at higher speeds? Crazy trucks have too many computers now. LOL
FYI, You won't likely measure full power at low speeds as the voltage applied is PWM (Pulse Width Modulation).
Only the 12V accessory power (charge) lead is going to have a measurable 12V. That's what's on F30.
PrescottNorm
Mar 20, 2020
Correct, no brakes at lower speeds and "Heavy over Hydraulic). I also have a sliding 5th wheel hitch that requires me manually apply the trailer brakes and move truck forward for operation, when OEM brake controller was manually applied to 100%, there was not enough voltage to activate the EOH pump (no brakes even while stopped), adapter fixed that as well.
CdnHO
Nov 17, 2020
Ontario
Interesting. I can lock up the trailer brakes to do a pull test when I hook up. The difference must be in the Dexter pumps and their compatibility with OEM controllers. My trailer is a heavy 2008 Newmar with factory hydraulic discs.
