2022 6.7 Cummins DEF Fluid and regens
Calef_HD
Aug 26, 2021
What are you guys seeing for DEF usage and regen frequency on the 2022 6.7? I just turned 2700 miles on my 2500 Laramie and added 2.5 gallons of DEF which bought the gage to 3/4 full. I’m now recording time and distance between regens but it’s done at least 4 times in the 2700 miles.
Do some seraching its been gone over lots… every 24hr run time it regens (unless DPF reaches high soot level) and about 1 jug of def every 1k miles
johnptc
Feb 12, 2022
i dont have a good fix on it, however 2022 burns much more than my 2015 6.7 in other wise identical truck
Papa_smurf
Oct 15, 2021
Mine runs about 1 gal of DEF per 1,000 miles. I've been through 3 of the 2.5 gal jugs of DEF and i'm right at 7500 miles, with 3/4 of a tank of DEF in the truck now.
tchur1
Jun 23, 2021
I just wrapped up a 2200 mile road trip and used about 2/3 of a tank of DEF, not towing, doing 80-85 the entire trip. I have about 2700 miles on the truck and it has regened twice, seems to run every 23-24 hours.
Calef_HD
Aug 26, 2021
Thanks for the responses! My truck did another regen this morning two weeks to the day from the last. 282 miles between and at 112 hours. That 112 hours is pretty close to what @H3LZSN1P3R statement of every 24 hours. The thing that gets me is I was on my way to work and continued driving for the extra 20 minutes and 20 highway miles ending at work a few minutes after the regen completed. The DPF gage was at 0. I left work and got 4 miles into my 9 mile commute driving 40-70MPH and the gage went up to 1/8. After starting the truck I only let it idle for about two minutes until the coolant temp surpassed 100 degrees. I don't get how the filter could clog 12.5% so quickly.
2001WS6
May 30, 2021
KY
The first one I ever caught. I left it on the DPF screen. I was up to about 45% and then the message came on.
I was driving home but decided to take it on the highway to see how long it would regen for.
Took about 25 mins. I was doing 70-85 mhp most of the time.
OuterUB
Oct 12, 2021
I'm at 2500 km and haven't seen a regen yet.
Have you left your evic on the DPF screen? Also what are your total engine hours?
He is most likely just at the verge or a regen being that it is in KM not miles 2500km depending on driving speeds puts him right in and around 24hrs
OuterUB
Oct 12, 2021
EVIC is not on the DPF screen but I'll put it there when we head back from Montreal on Sunday. Most of the miles (km) have been highway speeds.
flan
Aug 16, 2019
Ok if you want to know if your truck is in active regen it needs to be on the DPF screen. If not, other than a little deeper growl and dropping MPg you would be none the wiser.
OuterUB
Oct 12, 2021
Hmmmmmm... I DID notice a drop in MPG on the way up here from Windsor (9 hr drive). Is there any way to see if a regen occurred?
flan
Aug 16, 2019
If your engine hours (total) are past 24 I’d pretty much bet the bank on it. But other than that I’m not sure.
OuterUB
Oct 12, 2021
I was hoping that there's a log of the regens. I guess we'll see.
OuterUB
Oct 12, 2021
If your pulling your trailer it may just be doing passive regens
The first two trips were pulling... This was a Ghost Trailer trip. Here are a couple of EVIC pics...
OuterUB
Oct 12, 2021
Basically the truck is cleaning the DPF without doing an actual regen because it has enough load and is running hot enough
Wonder how often that actually happens ..... those are pretty high exhaust temperatures.
