2022 2500 Rear Seat Function
jlsalani
Sep 5, 2022
Brand new to this forum, my 2500 is on its way. Had a 1500 for the last 8 years and 171,000 miles. Question on the rear seat. I saw on the Ram website that the rear seat backs fold down?, but can't see if it is trim dependent or cab dependent. The site just shows it all and I have note been able to find anything on the internet? Any input for the current 2022 owners? I have a Laramie coming.
Only the mega cab seats fold down but there is a mod to make the crew cabs do it too
P.A.
Oct 26, 2021
We have a 22 2500 Big Horn and ours fold down. Use them like this all the time.
dieselscout80
Apr 23, 2022
Got a picture of them and of the latches/ release to fold the backs of them down?
jlsalani
Sep 5, 2022
So P.A... to be clear, you can fold down the rear seat back to a flat load floor?
elephantrider
Hydraulic Lifter Crew
Sep 3, 2019
it doesn't fold flat. it does fold forward enough to use the open area behind it to use it as storage.
Crusty old shellback
Apr 10, 2021
Sounds about the same as the back seat mod. Folds forward enough to stash some things behind the seat. Then the seat goes back in place. You still have the under seat storage.
Tdmva21
Apr 10, 2022
I have a 22 laramie. the seats fold up and there is the fold flat floor panel system that unfolds to create a flat floor. they fold up over the storage bin on the driver side and the sub on the passenger side.
dieselscout80
Apr 23, 2022
I know you modified yours by cutting some off the latch, but I wonder if a spacer under the seat mounts would accomplish the same thing?
LateToTheParty
Didn't want to come
Jul 29, 2020
Roxborough, CO
Yes, spacers or even a big stack of washers allow it to fold as well. I tested that route before cutting mine, but due to the way the metal bracket tapers, the seat back rattled quite a bit whenever there wasn't someone sitting back there.
Apr 10, 2021
The big issue is that the back slides up some when raising the lower seat section.
So you cut off just enough of the hook so that it clears as the bottom cushion is raised about half way. But not too much so that it does not hook and rattles.
I posted pictures and what I did for mine to just clear.
Spacers should work, but then the back is not fully seated on the hook when the bottom is fully down, or up.
K5KTF
Sep 22, 2022
Just got my 2022 2500 Lone Star quad cab last week.
The seats work identical to my 2017 Lone Star quad cab, the bottoms fold up and you have the flat boards with plastic flip out legs that then fold forward towards the fron seats to give a flat surface.
JBuss22
Oct 23, 2022
I read that there are pictures of the back seat mod but I can’t seem to find them. Can you please repost them or DM them to me?
Page 3 post #60 on his build thread….
Shadowboxin20
Jul 1, 2021
Ok, my back seat mod works great until I take it off road and the heavy bouncing will pop only one of them sometimes. It was the first one i did out of all the cuts and i think i cut the platic a little short on that one. Any ideas besides wrapping it in tape and praying. Wont pop at all if someone is sitting in the seat only empty
