2022 2500 Big Horn Truck Bed Holes
A is 7pin trailer plug hole, b is the switch for the bed lights cdc is for the for mentioned lights. B is for your imagination to run wild
MarkCO1
Feb 10, 2024
Colorado
Thanks. I better leave A alone as I will eventually have a 5th wheel.
wrvond
Sep 20, 2023
West Virginia, USA
B is the switch for the bed lights.
I suspect 'E' may have something to do with the manufacturing process and have no function at all. I've got that empty hole on the driver and passenger side, and at the front, there are corresponding holes as well, but they are both plugged with bed liner over the plugs.
scrmblr2
May 23, 2023
I’m thinking B might be a possible correction location for on board air for me. Easy access, protected, but far from front tires on truck.
Go go gadget search function to find more.
Grateful Dad
Aug 21, 2021
Georgia
Slightly off topic but does anyone know where to get the factory 7way/12pin for the bedside that comes with the factory tow prep? I’ve looked all over and can’t find it or haven’t found the magical name Ram has it labeled in the parts catalog.
A is the in-bed power. B is the bed LED switch.
7-pin trailer/12-pin camera is to the left of that as shown in wrvond pic.
whitexc
Jan 26, 2021
WNY
When I did the puck install and added the 7 way I bought a Curt plug and play. It came with a 90 degree plug for the limited space in the bed/rear quarter. It runs down and piggybacks into the bumper plug. Works great.
Sent from me
MEGA HO
Jul 20, 2020
Alberta
Amazon. Or any trailer accessories whop will have it and would install it too and will be cheaper than ordering OEM
dieselscout80
Apr 23, 2022
Sent from me
I used the Curt plug when I put one in my Rambox.
MarkCO1
Feb 10, 2024
Colorado
Anyone have the Curt part numbers or link? I am going to need that eventually as well.
Grateful Dad
Aug 21, 2021
Georgia
Well not sure how to efficiently tag everyone but I already have a 7way to run like I had on my ‘21, got it from Etrailer. I was just curious if the factory plugs/plate was available anywhere, I don’t have any use for the 12 pin at the moment but wouldn’t mind prepping the bed connection while I’m doing all this work (on the bumper I’ve got the 7way and 12 pin, no 4way).
