Thanks. I better leave A alone as I will eventually have a 5th wheel.A is 7pin trailer plug hole, b is the switch for the bed lights cdc is for the for mentioned lights. B is for your imagination to run wild
Slightly off topic but does anyone know where to get the factory 7way/12pin for the bedside that comes with the factory tow prep? I’ve looked all over and can’t find it or haven’t found the magical name Ram has it labeled in the parts catalog.
Ah good call, i don't have the in bed 110V so i gapped that was even an option lolA is the in-bed power. B is the bed LED switch.
7-pin trailer/12-pin camera is to the left of that as shown in wrvond pic.
Amazon. Or any trailer accessories whop will have it and would install it too and will be cheaper than ordering OEMSlightly off topic but does anyone know where to get the factory 7way/12pin for the bedside that comes with the factory tow prep? I’ve looked all over and can’t find it or haven’t found the magical name Ram has it labeled in the parts catalog.
I used the Curt plug when I put one in my Rambox.When I did the puck install and added the 7 way I bought a Curt plug and play. It came with a 90 degree plug for the limited space in the bed/rear quarter. It runs down and piggybacks into the bumper plug. Works great.
Sent from me
Did you have to cut a hole for the plug in the bed?I used the Curt plug when I put one in my Rambox.
Yes, you will need to get a hole saw and cut a hole in the wall for the plug and dr holes for the mounting screws.Did you have to cut a hole for the plug in the bed?
