2020 ram 2500 inside cab fuse to connect dashcam
kristof
Aug 27, 2020
Anyone was able to find where to connect dashcam so it will go off when truck is off and on when running?
There was a big thread about dash cams somewhere id do a search
kristof
Aug 27, 2020
After failing to find any fuses inside the cab of my truck I tapped into wires in my overhead console.
I was thinking the same. But I would like the dashcam to get power even when the truck if off.
Mikerob14
Jul 30, 2022
There is a whole thread on how to get power to a dashcam on here, but it’s possible to do what you want in a short answer. If you have AUX switches in cab then it becomes even easier. If not, you can get BATT by running to a wire down one pillar and IGN down the other pillar. This will give you the functions you want out of the dashcam.
kristof
Aug 27, 2020
I found the thread. Did look before but it seems I should have went through more pages of the search.
Mikerob14
Jul 30, 2022
No worries. I got some pointers from someone on here that I’ll share if you want. Like I said, AUX switches make it a dream to complete. I have my dashcam hardwired, and love it. It is possible without the switches, you just have to run those wires separate.
kristof
Aug 27, 2020
I do have AUX switches. But I seen somewhere there is a power at both side pillars. I would have to investigate more.
