2019 3500 Error codes
GLHOGAN
Oct 29, 2022
Weatherford, TX
My 19 Ram 3500 with 39k miles error code rap sheet: 1) installed K&N air filter, engine light came on. Dealer reset, installed Mopar filter. 2) While towing engine light came on, limp mode on. Dealer advised must use Mopar fuel filters. Corrected. 3) SRS warning light. Dealer replaced clock spring. 4) Engine light came on. Dealer advised error in DPF system. They reset it and advised to drive it and see if it reoccurs.
Right now I wish I had my old 2004 3500 quad cab again! Anyone with similar experience??
flan
Aug 16, 2019
Were those codes over the course of 39k? Not so bad on a modern vehicle with lots of electronics, unfortunately.... esp since 2 were self imposed.
So you caused 2 or more issues and you are blaming the truck? 4 little issues in 39k is not bad with the amount of electronic garbage on the newer trucks
