20 Laramie 2500 6.4l "overland" build
NHOverland
Jun 27, 2020
New Hampshire
Bilstein 5162s all the way around
Thruen Fab 2" Hemi leveling springs
Carli Adjustable Track Bar
Carli Steering stabilizer
Carli Swaybay (on the way)
CJC Offroad resi mounts and rear lower resi guards
NHOverland
Jun 27, 2020
New Hampshire
Installed a Switch-Pros 9100s to run all the things! Custom mounting bracket for module, mounted the switch panel where I was lacking the wireless charger, and used a daystar firewall boot through the block off plate.
NHOverland
Jun 27, 2020
New Hampshire
Yes they were. I'm on set 4, first were ruined by townfair tire, 2nd set lost 3 on the highway, 2 lost off road, and the 4th set in the garage. Wheel Pros replaced each set, but I have not heard back from Fuel after suggesting their China wheels need an update.
DontSlamMyRam
Dec 30, 2019
I ended up removing the rear springs/ret rings and just tapping the caps in till they were snug between the floater flange and wheel. For the cost you would have thought someone could have engineered something more robust. My wheels got lost in ups land for three weeks, then arrived damaged. It was two months of suffering from Fuel/MHT and XDP. After your story I really wish I would have sent it all back! Sorry, rant..
Truck Looks Sick!!
UglyViking
Jul 11, 2020
Man, I was gonna mount mine there but I've got that charging pad that I've grown quite fond of. I may check clearance and see if I can mount it on the pass side. Hard to install or pretty straight forward?
NHOverland
Jun 27, 2020
New Hampshire
It wasn't bad, it is double layered with plastic and the outside rubber. measure 3 times cut once! lol
