19 Current Gear Display
Enve46
Jul 20, 2021
Anyone know if or how to set the current gear to be shown all the time on the screen dash? I know I can hit the controls on the steering wheel but I’d like it to always display like my TRXs did. I have looked everywhere and can’t see a setting. It’s a 19 Limited if that makes a difference
snocam
Jul 23, 2022
Unfortunately I don't think it's possible to get the gear indicator up without having the truck in manual gear selection. I wish the gear position was always visible as well.
AH64ID
Moderator
Oct 5, 2021
I know AlfaOBD can enable it. JScan probably can too.
Enve46
Jul 20, 2021
Looks like I need to look into one of them. TRXs have it already enabled, why Ram wouldn't think an HD truck would is beyond me
AH64ID
Moderator
Oct 5, 2021
It’s available on the gas HD’s, and in the owners manual. Just not enabled on the diesels.
DrTron
May 3, 2022
No, it wasn't available in my 22 PW, either. But I got it enabled with AlphaOBD.
jsalbre
Oct 29, 2019
ID
It wasn't on my 2020 Limited gasser or my 2023 Rebel gasser. I had to enable it via AlfaOBD on both.
AH64ID
Moderator
Oct 5, 2021
So why is it available on some gas HD’s and not on others?
Darkside
Nov 22, 2020
When I first picked up my 21 the option was there to be able to turn it on but it didn’t work, then after the first software update it was no longer in my settings menu anywhere.
Gondul
Prince of Pintops
Mar 10, 2019
I'm thinking there is a bit of a difference in definition on what 'available' means.
Can you enable it when you use the gear limiter? Yes
Can you turn it on to display constantly in the EVIC? No (Unless this was changed with UC 5).
AH64ID
Moderator
Oct 5, 2021
Very possible.
Another one of those things that’s in the manual and not in the truck.
Perhaps there's some lack of clarity or understanding how it works.
Without being enabled from the factory, using the - gear limit selector will now show the current gear indicator until + is used beyond the highest gear or the truck is shut off.
Having it always display requires it to be enabled using AlfaOBD (perhaps jscan).
CdnHO
Nov 17, 2020
Ontario
J-Scan does enable it.
