UC5 uses a different method than UC4. It’s replacement for home split screen is just like @iflyskyhigh described. You can create multiple Home Screen layouts, and swipe through them. You can set car play on top, but not on the bottom.On my 2019 1500, I was able to use a split screen mode. Is this possible with the 2022 2500 Ram?
Hi Jimmy, on my screen I can only get Layouts 1-4, not the two Projection screens that you show in your first picture. I have a 2022 3500 with 12" UC5. I am accessing it with the touch screen icon at the bottom left of the screen (My Pages) and trying to modify so I can get CarPlay on the top box. Right now, I have the Nav widget in that slot - I have it set to three boxes, two quarters on bottom and half on top - and at times, the Nav screen disappears after a phone call through CarPlay which is running in the background. I don't see anywhere else in a menu to program this functionality and the dealership kind of quickly went through it with me - I have NOT yet read through the manuals; that is the plan for the next weekend that I am not jumping through flaming hoops elsewhere.UC5 uses a different method than UC4. It’s replacement for home split screen is just like @iflyskyhigh described. You can create multiple Home Screen layouts, and swipe through them. You can set car play on top, but not on the bottom.
You should be able to set nav to one half if you want. My default is nav on top, media on bottom.I think Nav uses the complete screen. But other pages can be set as split screen, at least on my '21.
I have the radio on the upper half and Climate controls on the lower half.
Right... I can the nav to do that. Ideally, I'd like Apple CarPlay on the top half of the screen, then two separate widgets on each of the bottom quarters. I've just been so dang busy I've not been able to really dive into the workings of this and then, every time I get behind the wheel I tell myself - damn - I need to set this up more efficiently.You should be able to set nav to one half if you want. My default is nav on top, media on bottom.
My only gripe is that you have to swipe away the "Favorites" or whatever on every start. Drives me nuts.
Alrighty… I’ll give it a go tomorrow. Thank you.It will only allow you one personalized page with the nav and one with car play. If there is another page already using one of those widgets delete that page, and create a new page with the widget desired
