12 inch UConnect 5 cargo camera in 2022 Ram 2500?
SeanF
Sep 15, 2022
Hi All,
I have been trying to figure out how to connect to the unused cargo camera input on my 2022 Ram 2500 with the 12 inch UConnect system. Everything I have found online refers to a previous generation with a large 52 pin connector on the back of the radio where the cargo camera can be connected to pins 21 and 22. Apparently changed this to multiple connectors for the 2022 model with the 12 inch screen. (See Attached Photo).
Does anybody have a connector pin-out for this newer radio?
More information:
- Truck is a 2022 2500 Laramie with the 6.7 Cummins standard output
- I do not have the surround camera system
- I am going to use this for a front camera.
- I can enable the cargo camera with AlfaOBD
- The camera I have is powered and working
- The camera is a 480P that is using the yellow RCA composite video connector.
Any helpful info would be appreciated!
ramreddog
Jan 5, 2024
Crashing HD with my 2023 Ram Rebel, but have the same issue. I purchased the Tazer DT and A/V kit (for a front camera) to find out that I also have no 52-Pin harness. I was able to go to the dealership and get a pinout for the blue connector (RADIO C2 ASSOCIATED RFL ONLY) connector (which I will post in the next day or so), but the pinout I have shows only the circuit, gauge, color, function of the pin slots that are occupied/used in this 32-Pin connector. If you orient the blue connector where you have the four pin female slots on the top (with the four rows of seven pins on the bottom), the top pins are 1-4, starting at the top-right. The numbering of the right-most columns for the remaining 4 rows of seven are: 5, 12, 19, 26 (all pin numbers increase from right to left). The confusing part to me was that the number of female slots seemed to be twice as much, but if you reference the male portion, you will see there are actually 4 pins at the top and 28 in the 4x7 section of the bottom. So, when you reference the female portion just realize that each row of pins/pin-outs involves two rows of holes. (Hope that was not to consusing). But when I take a close-up of the plug side/female side, I see on my vehicle that pins: 8,9,15,16,22,23,24,28,29,30 seem to be empty. And, of course, the pinout does not say what those are. So, I forwarded the above details to Zautomotive last evening and will see what I hear. I think that we are just too close to the "bleeding edge" with our efforts. Hope this helps, if only that I am currently sharing your pain.
SeanF
Sep 15, 2022
I know this doesn't answer the question about where to wire in the cargo camera and the UConnect 5 connectors, but this may be useful information for somebody out there:
I ended up installing a Naviks unit into my 2022 Laramie. OK, It is not factory and is a bit on the expensive side. I am using the Naviks unit for a front and blinker cameras. I have the blinker cameras coming on automatically with the turn signals (set to can bus option) and the Front camera is triggered with one of the Aux switches.
I used the relatively cheap Amazon automotive backup cameras. The Naviks unit supports a rear camera and HDMI input as well, which I am not using. The instructions are not very good, but I was able to figure it out. I had to call the Naviks tech support. It is also a challenge to find a place behind the dash to install the Naviks unit.
Another option I was considering was the cargo camera kit from Infotainment.com. They have the connectors with the break-out for the camera inputs.
Hope this helps.
ramreddog
Jan 5, 2024
Update: Zautomotive is working on integrating with Uconnect 5. I sent them some pictures of the connectors (blue: C2) and (green:C1) with pins located on both sides of the connectors based on a pinout I received from a dealer (for blue:C2) and a pinout previously uploaded to the 5thgen ram group.
