I have a 2020 Ram 2500 Bighorn, I have stock halogen lights, just bought 20 Laramie lights. Is the harness available or what are my options?Send Jeremy an email. Not in mass production yet. He’s sold a few sets based on requests. He sells OEM lights and the harnesses. What I mean by “lights” is the entire headlight housing. He sells the housings from Mopar and the harnesses which he makes in house.
Read the thread, literally step by step instructions how to do this.I have a 2020 Ram 2500 Bighorn, I have stock halogen lights, just bought 20 Laramie lights. Is the harness available or what are my options?
If you want the LED reflector version that are essentially plug and play they are 68360178ac and 68360179ac. The LED projectors require some wiring.
On a side note I just did this mod to my Dad's 2019 2500 and after making the changes to the BCM, the low beam on the leds stayed on all the time. Finally figured out that in his halogen lights the low beam was set as a DRL and had to be disabled.
Thanks for the part numbers, I’m assuming these will work with my 2020 4500 tradesman? In my research not everything references 4500/5500’s.Just as a note for researchers purposes, those P/Ns are for "signature" standard, non-adaptive, LED Night Edition (black) headlights.
They are the same yesThanks for the part numbers, I’m assuming these will work with my 2020 4500 tradesman? In my research not everything references 4500/5500’s.
Some folks have been able to get the black bezelled oem halogens on rock auto, they may have the leds too.Thanks for the numbers, although I am looking for the projectors night edition. Retro shop has them and a harness, but that is more expensive than finding the part number, figuring out what wires to run and using alpha. I may just go with retro shop solution or the morimotos. Either way I would have to run a harness. Thanks again.
Projector headlamps with black bezels:Thanks for the numbers, although I am looking for the projectors night edition. Retro shop has them and a harness, but that is more expensive than finding the part number, figuring out what wires to run and using alpha. I may just go with retro shop solution or the morimotos. Either way I would have to run a harness. Thanks again.
Thanks Jimmy07, that would be awesome. I have plans to add a lot of the OEM options, do you mind if I PM you to get your input?Projector headlamps with black bezels:
Left- 68360183AB
Right- 68360182AB
If you use AlfaOBD, I can build the harness for you that will make them function 100% factory, including the adaptive feature.
Sure, no problemThanks Jimmy07, that would be awesome. I have plans to add a lot of the OEM options, do you mind if I PM you to get your input?
I am about to make the change but lets say I mess up my truck changing the settings in AlfaOBD (first time using it) am I able to easy just restore the original settings?
