Aux Switch wiring location
I just did some re-wiring on my 20yr old motorcycle and it was a headache (for me)... that would drive me nuts!
Looks good though!
Aslong as you can keep your wires labeled its not bad you can make a rats nest turn in to something much cleaner.... my 5 relay harness for plow light wiring... the plow dealer wanted 2500$ For the plow wiring i spent 150$ and a few things from work
@Jimmyo7 Hi Jimmy. I am going down this road on my 2024 Ram 2500 Rebel. I am wanting to tap the wires into the x/y 125A plug as well. Is there any chance that you could provide an actual picture of which plug this is under the dash? I am pretty sure i know which one but i want to make good and sure before i tap into it. I'm going the route of buying the Auxiliary switch kit that Mopar has pn 82216450ab and robbing all of the wires and stuff out of it and installing into my existing PDC. I think it will be the easier route for me than trying to create all of the wiring from scratch. I'm not interested in getting power to the back of the truck as some people are with tapping the x/y 920. Any advice or help would be greatly appreciated!
I don’t have a picture of it plugged in, but I took this one of XY125 when I did my install. It should be pretty easy to find with the yellow tape.
Trying to add an aftermarket 6gang aux switch. Trying to tap into an acc wire but I’m a little slow. These wires capped off next to the fuse box have any use since I’m in a tradesman?
@BadKarma
I believe that these wires are for the snow chief prep package. See the diagram below. As far as are they "active" wires. that i am not sure of. I want to say that they are not though. I could be wrong. I am still learning the ropes on these acc wires.
Assuming you're just looking for power for the control part and not trying to power multiple accessories from this circuit. High current Power draw should be connected to the HAPP bar on the battery.
I believe that is correct. I have The power for the control box connected to the battery bar. I am Looking to connect the wire (b) from the control box (assuming it’s for the controller) to an ACC source.
Everything is positioned in painfully easy-to-access locations on the 2025. More spread out. No digging required to find them. And the 2 rear wires are now the same size.
Anyone know what gauge these rear wires are? Wondering if it's big enough to handle a 23 max-amp air compressor. My manual says I need 8awg.
Also, is there a Ground wire supplied at the rear? Or a really good spot to ground to back there?
View attachment 87656 View attachment 87657 View attachment 87658
Unless something changed, the wiring chart shows those circuits IGN/BAT+ are fused 20A.
You're also running through the in-cab jumper harness.
If anything, I'd pull one off the lead end and tie them together to carry more current. A500/A606
The AUX wiring is rated to 40A (28A continuous), but length is much shorter there with the supplied jumpers looking to be 10AWG.
Chassis ground is good to 50A.
Another good option if you want to put it on an AUX switch is use the pass-thru circuits and re-pin one AUX to connect to the in cab jumper on pins 1&4 that run to the rear.
Then you still have an IGN and BAT+ source available at that in cab connector.
I like the doubling up Run/Batt to double the ampacity. That's what I did with my Charger's Aux switches for a big light bar.
However, I'm planning to connect Aux2 to the Pass-thru to the BATT to control the rear lights.
I was intending to swap in a 40A fuse for the RUN wire from one of the Aux. The physical size of the RUN wire vs. my Logiq compressor's supplied wire appear to be the same size, and the Logiq wire is longer than the truck. Wish they'd just print the AWG on them.
The quick connects are my only concern using the RUN wire for the compressor. Those seem to be where I always see failures from overloading.
Finding a ground spot that won't rust out in the winter is my biggest concern now. The Charger's pre-wired Aux connections gave you + and - wires which was really nice.
I was also looking at going with LogIQ (AirIQ HD2) and have been debating on how to install, either letting the system track voltage to turn on/off OR wiring the orange wire into an AUX button so I could cycle it on/off that way. Shouldn't need to connect the red wires to the power distribution just go straight to the battery.
I just put it on my 06 Duramax and connected their orange wire to an Ign wire, and yet it still turns on when the truck is off. That's why on the Cummins, I want to supply main power via the RUN (ign) wire, so that it can't run with truck off.
The downside to allowing it to run when it sees 14+ volts is if you put a trickle charger on the truck while it's in storage or your truck's dead and needs a jump.
Did LogIQ know why that was happening? It should have not been running if the IGN wire you used wasn't hot with truck off cause I assume your Duramax batteries weren't floating at > 13v LOL. 100% with you on the trickle charge scenario it would just stay constantly energized thinking the truck was running thats one of those possibilities that was leading me to using up one of the AUX ports to control it using the orange wire.
Anyone know what the Brown/Grey wire in port 2 does?
You should look through the sticky below the image:
W550 Pin 2 BG/GY pass-thru circuit. It will be bundled with 3 other blunt cut wires near the Aux PDC in the engine bay. Those other 3 are on the white upfitter jumper if you have a 21+.
