Feeling like kind of a dummy right now....
I installed the Kaodtech bypass cable, hooked up my OBDLink MX+, and connected via my laptop to change the tire size. I used the guide in the google docs posted on this forum which has you select the MY2013-2017 BCM and I think I also used the 2013-2018 ABS option. Looking back I see a MY2020 option for the BCM and a MY2019+ ABS option...
Did I screw anything up by using the older year model options? If so, can I just redo the procedure with the newer options?
